6x.020 Injectors
They take your stock injectors you have in it now and they hone them out to whatever size you want i think so they are custom. 6x16's are pretty big but they're not too big
. Considerably bigger then pods and bigger then DDP 80's. I'd say there good for a 100 HP gain with wannadiesel pump tuning.
If your drive line can hold it.
. Considerably bigger then pods and bigger then DDP 80's. I'd say there good for a 100 HP gain with wannadiesel pump tuning.If your drive line can hold it.
Would 6x.014 injectors be too large for a truck with the 60mm compressor housing/wheel upgrade, Powerstroke intercooler, and CoolerTubz pipes with the pump turned up 3-4 full turns on the power screw? Oh yea, I don't think I ever got an answer to this but are the DDP 80's a 5 or 6 hole injector? It seems the 4 and 5 hole injectors are less efficient with more exhaust smoke made at any RPM even idle, but I guess if an injector is a 5 hole that's EDM'd instead of extrude honed it is "machined" more precisely (allowing for a more complete, efficient burn but still makes for a good HP/TRQ increase mind you). I'm going to be buying injectors here pretty soon and am just about mind set on going with a 6 hole performance injector to in a sense resemble the factory injector's 6 hole design. But, I heard the DDP 80's are very clean burning for what they are and do add good power. Either way if I buy them or get a custom 6x.012 or 6x.014 injector package made I'll be paying over $700 no matter what. Oh well, it all goes to say that it's great to be power hungry! (haha).
Sal
Sal
The DDP's are roughly 5x13's. Since the holes are supposed to be ovaled a little, they're supposed to flow more than if you got a straight set of 5x13s made. They burn super clean, but I think they could be a little bigger, maybe around 70lpm.
Sal
Sal
TxDiesel007
Feb 18, 2007 10:42 PM
Meatball
Apr 24, 2005 10:27 PM
