gauge install
Old Jan 24, 2009 | 06:59 AM
zethtays's Avatar
gauge install
I was looking throughthe sticky hoping to find an article on gauge installs and which gauges you should have to keep an eye on the truck I would like to have a boost tach and fuel pressure gauge but didnt know what brand and what measurements on the gauge i should be looking for. as well as install
Old Jan 24, 2009 | 07:03 AM
zethtays's Avatar
anyone have personal prefrences as far as brands and were to in stall them
Old Jan 24, 2009 | 07:31 AM
Bob Beauchaine's Avatar
I use AutoMeter, they have a wide range of different models that will work. Isspro is another one I've used and like in other vehicles.
Bob
Old Jan 24, 2009 | 08:17 AM
DNRCustoms's Avatar
auto meter on mine, I've always had good luck with them.. I'm pretty sure there is something in the stickey to help you out.. Get a good test light and it will make the job easier.. I like to get my power then daisy chain the guages together.
Old Jan 24, 2009 | 08:53 AM
SmokemS's Avatar
i use glowshift gauges....nice and bright at night and very reasonable in prices....glowshift.com
Old Jan 24, 2009 | 08:58 AM
Richie O's Avatar
366 Spring Chicken
Pryo is most important gauge. I did not see you list that one. I have isspro and autometer.
Old Jan 24, 2009 | 08:59 AM
Richie O's Avatar
366 Spring Chicken
Most common size is 2 1/16 inch.
Old Jan 24, 2009 | 10:12 AM
ofcmarc's Avatar
I like Autometer. The Dynafacts came with the truck when I bought it.
Old Jan 25, 2009 | 05:38 AM
KRB's Avatar
KRB
Westach . Aircraft quality and you can have several readings per gauge.
You asking where to install the gauge itself or the sending units?
Old Jan 25, 2009 | 06:34 AM
zethtays's Avatar
the sending units mainly i purchased a two gauge pillar from auto meter and im going to purchase one of the three gauge as shown in one of the pics someone posted
Old Jan 25, 2009 | 07:39 AM
KRB's Avatar
KRB
Stickies will show best install for boost & pyro.
What are the gauges you plan to have?
Old Jan 25, 2009 | 08:28 AM
zethtays's Avatar
2 1/16" boost, fuel pressure, tach pyro
Old Jan 26, 2009 | 12:55 AM
KRB's Avatar
KRB
What year truck?
Boost should be easy, just swap the plug under the intake with the fitting.
Tach depends on year and brand.
For the pyro read the sticky. Tapping into the exhaust manifold isn't hard but you have to do it right.
Can't help with fuel pressure, haven't done that one but it is next on the list.
Old Jan 26, 2009 | 06:43 AM
zethtays's Avatar
its a 93 w250 auto, could comeone post the link to the articles in the sticky i saw the tach but couldnt find the others i must be just looking over them,
Old Jan 27, 2009 | 04:58 AM
KRB's Avatar
KRB
Hmmmm, you're right. I couldn't find it either .
Your '93 should be easy.
There's a plug in the head directly under the intake (like a 1/4" maybe??). Screw it out & install the barbed fitting that comes with your boost gauge (or buy at NAPA, Lowes, etc).
You already have wiring for a stock tach under the dash above parking brake. An Issopro will wire right in. Not sure about any other brand.
Both are super easy/quick.
spooled142
Mar 19, 2009 09:10 AM
ado2b1
Jul 6, 2007 10:27 PM
QWKRTNU
Sep 26, 2006 10:22 PM
BigK
25
Mar 28, 2003 07:31 PM
