62/80
Old Oct 16, 2008 | 09:38 PM
Ezra's Avatar
What is yours guys opinions on a II super phat shaft 62/80?
Old Oct 17, 2008 | 04:17 AM
ryanihf250's Avatar
I don't have the 62, I have the II SPS 66. I like it but I use it mainly for pulling. I can't spool the turbo till about 1,500 rpms but it is better than the stock turbo. I think the 62 would spool real well.
Old Oct 17, 2008 | 04:34 PM
I think the 77 turbine is a better match for the VE.
Old Oct 17, 2008 | 09:14 PM
Ezra's Avatar
Well i ordered a 62/71/14.and when the turbo got here it is a super phatshaft 62/80.should i keep it or return it?
Old Oct 18, 2008 | 05:54 AM
That's not gonna spool well.
Old Oct 18, 2008 | 08:20 AM
JAyers's Avatar
Mine starts around the 1300rpm range and by 1500rpm ive got 10psi and its ready to rock. Keep it you will like it, ive ran mine with stock injectors to 6x.018's and love it! Pluss it will support some nice numbers!
Old Oct 18, 2008 | 11:15 AM
Ezra's Avatar
how will this 62/80 and 6x.016's work? I'm looking for a big improvement over stock.and i dont want a turbo like my stock one that takes awhile to spool.
Old Oct 18, 2008 | 01:53 PM
JAyers's Avatar
it will work great. Its alittle smokey on the bottom end but and with a hot pump is still a tad bit hot at WOT but i feel its the best compromise between a big charger and a fast spooling smaller one. It just take alittle getting used to. Once they build 10psi hold on cuz they are gone after that.
Old Oct 18, 2008 | 07:52 PM
Josh, I thought yours was a 62/77?
Old Oct 19, 2008 | 07:26 AM
JAyers's Avatar
No sir, its a 71mm.
Old Oct 19, 2008 | 07:23 PM
OK, so comparing how that spools to a 62/80 is apples to oranges - or did I misread your first post and you are recommending he send back the 62/80 as well?
Old Oct 20, 2008 | 04:13 AM
ryanihf250's Avatar
My turbo was the same way when I got it. I thought it was going to be a II SPS 66/71/14 but then the tag on the turbo said 66/80. I have no idea what is up with it though.
Old Oct 20, 2008 | 08:08 AM
JAyers's Avatar
Ok guys, 62 is the mm of the compressor wheel inducer and 80 is the AR of the exhaust housing. Which comes out to be 14cm. All super phat shafts run a 71mm exhaust wheel and all the silver bullets run a 73-74mm 10-11 blade exhaust wheel. To my knowledge no one makes a S300 with a turbine wheel larger then 74mm. In other words I run a 62/80 too.
Old Oct 20, 2008 | 08:18 AM
bgilbert's Avatar
Josh thanks for breaking it down to the guys. Gotta love all the fancy names the vendors give these off the shelf chargers/parts. What's II getting for one of these, pm please.
Old Oct 20, 2008 | 09:11 PM
Ezra's Avatar
yeppers, your right Jayers.Just got a email from John at holland court diesel,and he said 6280 is the part number.Ezra
