518 trans to 47rh T-Case ??
Hey guys,
I have been searching the swap for some time and it seems pretty easy. I just got off the phone with a guy that will sell me a 47 rh for 500 bucks, complete trans, converter, adapter plate and starter. The best thing is it came out of a 95 working truck. So I am in like flint. My question is, on a 94 or 95 truck did it have the same 205 t case. I thought I read it did somewhere but just want to make sure it will line up. I know I have to make a few adjustments to the driveshafts and trans mount, But that is no big deal as long as it bolts up to my t case. thanks
If you haven't already done so, read this,
https://www.dieseltruckresource.com/...d.php?t=114702
Nope 94-95 trucks came with a NP241D I think, got 2 of them at home from a similar deal to yours. Driver side drop, aluminum case chain driven. A 205 will bolt right up to a 47RH, just have to use RTV to seal the flanges. Some 47RH's have a drain in the OD section and some don't.
JD, where have you seen a 47RH 4x4 output with a seal for the 241 input? Every one I have busted apart, did not have a seal in the trans tailhousing, thus it can be used with a 205, with the same sealing gasket used with the 518 setup.
(I see it is mentioned in the reference website, yet I have yet to see a 47RH with any seal as mentioned. The regular paper gasket and the coupler, just like the 518 can be used).
As far as the O/D 4x4 housings, both castings are identical, so the 205 TCase will bolt right up.
I have seen 2 so far both are mine, I just pulled another 47RH/NP241 apart the other night and it has the seal installed in the case. The years cast in the OD case are 92/93, when I looked at the drain it is blocked, my other one which is a 94 year casting has the drain that is not blocked.
