something bad, plz help
Old Jan 8, 2008 | 01:31 PM
93beater's Avatar
Red face something bad, plz help
my speedo quit on the way home from school, wouldnt shift into OD, and is making a horrible ticking noise sounds to be commin from right under the cab, i drive this thing a lot and i need it back on the road asap, and help or opinions are greatly appericated! thanks a ton,
cody
Old Jan 8, 2008 | 01:43 PM
pulltilbroke's Avatar
Best Paint (Getrag category)
Check your vehicle speed sensor
Old Jan 8, 2008 | 01:53 PM
JD730's Avatar
Yup speed sensor or its drive. For the clicking, check the driveshaft slip joint. I've heard them make that kind of noise before. Also check the u-joints, you could have a dry one starting to go.
Old Jan 10, 2008 | 11:17 AM
93beater's Avatar
where is the speed sensor and how do i check it, any other ideas on the nasty tick knock tick noise?? i really need this fixed
Old Jan 10, 2008 | 12:35 PM
Chrisreyn's Avatar
There are several pics of the VSS on here , search for it and there are a couple good threads on how to test it and replace it and what commonly goes wrong with it..
Old Jan 10, 2008 | 12:38 PM
bendturbo's Avatar
If all that happened at once check the speedo gear at the output shaft
Old Jan 10, 2008 | 01:38 PM
93beater's Avatar
it was making that knock tick noise for about 3 days b4 but wasent bad at all then the speedo wnet crazy 2 days ago, and the knock is nasty!
Old Jan 10, 2008 | 02:08 PM
Chrisreyn's Avatar
Just a thought, but check the output shaft nut for tightness. If loose, it could, in theory, cause a ticking, and once loose enough can cause the VSS to stop working..
you have to drop the drive shaft to check it, but it might be worth doing.
ramdez
Dec 28, 2009 03:55 PM
Arkangel77
Jan 8, 2006 12:00 PM
12valve
30
Dec 25, 2005 10:01 AM
taildragger
Oct 23, 2005 10:56 PM
storx
Jul 22, 2005 06:12 AM
