5.9 ve tuning
Old Aug 7, 2025 | 06:58 PM
  #61
Originally Posted by Oran
oh wow, thanks for the heads up. That means its likely not modded yet, and that the performance can get better yet still. Sweeet.
I am not sure what mods you have planned for a 400,000 mile HX35, but it appears like a pretty stock 2nd gen turbo to me.
Which I find good enough for almost all my 1st gen motor builds.
Old Aug 7, 2025 | 07:00 PM
  #62
Oran's Avatar
I doubt ill mod this one, ill likely rebuild it, replace wear items and such, but im lukely going to look for a 6067 cistom hx35 or get the 6064 agressor for power driven. But i need to replace my 4 hole inchectors of unknown origin and my lift pump first
Old Aug 8, 2025 | 04:26 PM
  #63
Oran's Avatar
Not perfect but it should do the job
Old Aug 8, 2025 | 04:47 PM
  #64
Oran's Avatar
Well shes got 11 psi and holding so far. Chargi e a spare security camera so i dont have to keep going out there. Do you think that if it holds it might be safe to assume that the brass magic bullet could be the issue?
Old Aug 9, 2025 | 07:27 AM
  #65
Rug_Trucker's Avatar
5 Year Member
Once I get my beast running I have a 3 piece DAP manifold. Will drop on a 62/64 HX35 I bought from DAP. The advantages of a newer design compressor wheel over the stockers is more efficiency, and faster spooling. I've been following PDD's channel. Not much in there for VE people. However watching their turbo videos although interesting, is mostly geared to the P pumps.
Without the expense of converting to a P pump the VE is capable of producing 550+hp without screwing up your fuel consumption. I have a spare VE pump that will go to Ratman Performance. I have a Max fueled THD hanging on the motor now.
Old Aug 9, 2025 | 07:57 AM
  #66
Oran's Avatar
So the fuel system held 11 psi for over an hour but not over night. My first time using this sort of test so i have no idea how to interpret that
Old Aug 9, 2025 | 08:46 AM
  #67
You have a leak, should be the interpretation.
Old Aug 9, 2025 | 09:35 AM
  #68
Oran's Avatar
i figured that, just curious because im seeing feeling or smelling a leak. Ill pressurize it again and look again.
Old Aug 9, 2025 | 09:44 AM
  #69
Where are you “seeing/feeling or smelling a leak”?
Old Aug 9, 2025 | 09:45 AM
  #70
Oran's Avatar
That was a typo, i meant im NOT seeing feeling or smeeling fuel
Old Aug 9, 2025 | 09:51 AM
  #71
Oran's Avatar
Old Aug 9, 2025 | 09:57 AM
  #72
Even without the “leak tool”. It is safe to assume the new air leak that happened after you worked on the fuel system, is for something you just did. You need to check your recent work / re-tightened up things that you just worked on.
Old Aug 9, 2025 | 10:00 AM
  #73
Oran's Avatar
I get that, i was an aircraft mechanic for nearly 20 years, im used to "if soemthing new doesnt work what did we touch", im just wondering if i cant detect an external leak, could the brass magic bullet i installed in the fsv be the issue? I cant find any info online about proples experiemce with it. Only marketing material.
Old Aug 9, 2025 | 10:19 AM
  #74
It is possible. Might want to swap it out for the OEM one.
I have heard of people that used that product have issues with their truck not shutting off. Which makes me guess the brass tip is not as good at stopping the fuel flow to the pump.
Old Aug 9, 2025 | 05:16 PM
  #75
edwinsmith's Avatar
What about the return line? could it be leaking back into the injectors? Try plugging it off for the next test to narrow things down a bit.
