47rh trans question
Old Jun 26, 2006 | 10:42 AM
squirrel's Avatar
47rh trans question
I was reading some info on here and I believe the trans that I got form ATS is a 47rh. Just to make sure the 47rh looks like the 518a but on the passenger side it has webbing sticking out that is part of the trans case? If it is a 47rh what do I have to change to the inside of the trans to make it work with a lock up converter?
Old Jun 26, 2006 | 12:06 PM
JD730's Avatar
ATS probably used a newer case to build your A518, thats why it has the reinforcing webs on it. Internal parts are what need changing. Input shaft, front pump and cover, valve body, etc.
Old Jun 26, 2006 | 10:49 PM
kennedy's Avatar
sounds like ATS just used the newer style case (47RH) and then more than likely used the non-lock up internals (valvebody, pump and input shaft) from the a518. For the most part, the tranny's are identical internally, and exteranlly, main difference were a few beefed up internal parts, which can be swapped in, and the changes needed for the lock up.
Old Jun 26, 2006 | 10:59 PM
squirrel's Avatar
It dose not have a lock up converter in it now. Was toying with the idea of putting one in and wondered what was required. I know about what needs to be done externally just not internally.
Thanks for the help
Lester
15
Jun 13, 2010 08:25 PM
DNRCustoms
Jan 10, 2008 12:30 PM
scottmn1
Jan 25, 2007 07:53 PM
Lester
Jun 13, 2005 07:59 PM
