47RH Swap Questions
Old Sep 5, 2007 | 11:01 PM
Free89W350's Avatar
47RH Swap Questions
Ok I saw in the sticky that if I want to do this I need a trans from a 95ish truck. I have a line on a 47rh out of a 99 and was wondering what is the difference between this one and the earlier one. Would the newer one be ok for me to use or should I just wait and get a earlier one. After riding in JD730's truck this is definitly the way I want to go. Your help is appreicated and thanks in advanced.
Ryan
Old Sep 5, 2007 | 11:06 PM
92DuallyCTD's Avatar
Wouldn't the 99 have a 47re(or maybe 48re) instead of the rh? You may not want to attempt an re(electronic controlled) swap, much easier to do the rh(hydraulic controlled) one. About the only quick way I can tell is the rh's have an oval 3-pin connector, the re's have like an 8-pin square connector(I think...). What years/models were the rh vs re? Anyone...anyone...
Old Sep 6, 2007 | 01:49 AM
Fergavs's Avatar
I have the 47rh trans. I bought mine from BD-Power but it is for a 94-95 dodge cummins. You also need 2wd or 4wd specific. Its the simple hydraulic activation that is desired as mentioned above because the trans is a simple 3 wire hook-up and can be controlled by two rocker switches. I have done a number of posts with a fair amount of info in them.( just search my past posts,should say 47rh in title) If you have questions feel free to PM me i'll try to help.
I couldnt be happier with my auto. The truck is a monster. Much faster then the 5spd and more reliable as well.
Old Sep 6, 2007 | 08:14 AM
JD730's Avatar
Ryan,
A 99 trans will be a 47RE. It is not hydraulically governed, it has a speed sensor in the trans, gov pressure sensor and a gov pressure solenoid to regulate the gov pressure. Overdrive and Lockup are activated the same as a 47RH. The primary differences are the valve body, overdrive section and the overdrive piston retainer. Overall length is shorter than a 47RH.
The 47RH in my truck used to be a 47RE out of a 96, took the OD off my A518 and the gears out of the 47RE, used the better parts, gears, etc... New OD piston retainer plus transmission overhaul and I was good to go.
I'm going to PM you my number so you can call me, I might have a line on a 47RH for you.
94 and 95 where the only years they used the 47RH in the trucks, 1996 started using the 47RE and continued to early 2003.
aer212
Jan 22, 2011 12:22 PM
peobryant
Apr 18, 2009 07:58 PM
getstucksome
Feb 24, 2009 09:58 PM
scottmn1
Apr 28, 2006 03:26 PM
GO 4LO
Mar 18, 2005 07:49 AM
