435's and timing
Old Sep 11, 2009 | 10:29 PM
SOOT4BRAINS's Avatar
Pod Boy (on hiatus)
435's and timing
Ok so SMKHZRD came over today and we advanced his timing a tooth. We also got a metric dial indicator and the adapters to check the timing. It is too far advanced now, we need to back it off but we ran out of time to put the timing tool on it to see where it really is. Here is his sig so you can see his mods.
1993 w-250 4x4 dual 6'' mitre cut stacks,4 inch dp,Bhaf, ATS Manifold, 435 injectors,62/65/12, new ve pump(tweaked), new A518 trans,Gorend TC, 3200 gov. spring, Raptor 100 eletric pump,AFC lever gone, Isspro Gauges, tach, pyro, boost,tranny, fuel pressure, custom 5 pillar gauge holder
What do you guys think would be a good starting point for setting his timing?
Old Sep 12, 2009 | 01:23 AM
Greed 93's Avatar
I would say 2.0 mm is fine imo if there is no towing going to happen keep advancing it till it starts to buck or pop then back it down alittle.
Old Sep 12, 2009 | 10:40 PM
Pod Boy (on hiatus)
Thanks for the help. We set it at 1.9mm, as he may do some towing with it. Runs good and sounds good.
97CTDRAM
Sep 8, 2009 06:15 PM
onetwopunch
Nov 20, 2007 10:57 AM
Wild Wills CO
Aug 4, 2007 11:41 PM
dodgeramrod
Feb 13, 2007 12:43 PM
tmacie
18
Oct 14, 2006 04:19 PM
