435 are in!!!
Old Aug 6, 2009 | 10:42 PM
SMKHZRD's Avatar
435 are in!!!
Couple questions got my 435 in and it seems the same as my ddp3 that i took out...it should be a whole lot faster? could it be that my afc lever is gone and is dumping more fuel in and bogging it down and/or that my gorhend tc is loading down the motor early....
Old Aug 6, 2009 | 11:38 PM
JQmile's Avatar
My 6x16's didn't make any more power than my DDP4's, they just smoked three times as much....that was before I hit the bottle anyhow. Big injectors require lots of air and timing...maybe more than your 60mm can provide.
Old Aug 7, 2009 | 05:47 AM
archer39's Avatar
more timing will make them come alive.
Old Aug 7, 2009 | 10:24 AM
SMKHZRD's Avatar
my pump is already turned to the block...would i need to jump a tooth?
Old Aug 7, 2009 | 10:45 AM
apwatson50's Avatar
yep
Old Aug 7, 2009 | 05:47 PM
SMKHZRD's Avatar
so any other things i can do i plan on getting a s300 for my setup...
Old Aug 8, 2009 | 01:17 AM
Benjamin b2's Avatar
um, winshield washer fluid injected into the intake manifold at a high pressure
Old Aug 8, 2009 | 08:38 AM
archer39's Avatar
Originally Posted by apwatson50
yep
x2, when i jump a tooth i noticed more of a power increase then when i installed the injectors . every truck is different though.
dieselJon
Dec 12, 2007 08:11 AM
onetwopunch
Nov 20, 2007 10:57 AM
Wild Wills CO
Aug 4, 2007 11:41 PM
dodgeramrod
Feb 13, 2007 12:43 PM
tmacie
18
Oct 14, 2006 04:19 PM
