4:10's to 3:55
Old Oct 22, 2010 | 01:33 AM
mullishacrew's Avatar
4:10's to 3:55
hey, i have a pair of 3:55 geared axles sitting under my ramcharger that are out of my previous w250, i recently bought a 90 w250 and it has 4:10's with 38" tires, would the 3:55 geared axles be worth swapping into the 90 w250? will i gain more in fuel milage then having my 4:10's?
Old Oct 22, 2010 | 04:48 AM
KD93's Avatar
Yes, but I don't know how much. Lame-o answer, I know...
Old Oct 22, 2010 | 08:11 AM
rustydeeretech's Avatar
i have a 1991.5 w250 5 speed and i get 23-24 mpg with 3.55 i have a 1996 2500 4x4 with 4.10and i get 18 now that is p pumped so its not that same truck as the 91 and its also a auto but at 65 iin running 2000 rpm where with 355 im running less dont have a tach so cant give real numbers
Old Oct 22, 2010 | 08:56 AM
maybe368's Avatar
doesn't make much difference, but aren't they 354s? Mark
Old Oct 22, 2010 | 11:07 AM
MrExtreme's Avatar
38s and 3.55s, you will be using first gear a lot more, it won't be so much like a granny gear with that set up. Might actually get decent mileage around 80-85, thats about where mine starts dropping off rapidly with 33s and 3.55s.
Old Oct 22, 2010 | 12:05 PM
raggmann's Avatar
I've got 35's with the 3.55's and it's pretty good top end but 4.11's would work really well as far as pulling off the line.
Old Oct 22, 2010 | 02:22 PM
With the 3.54's I have in old RAE I cruise in 5th on the freeway at about 1700 rpm @ 65mph. But I'm running the stock size tires, 235/85/16's.
Old Oct 22, 2010 | 10:34 PM
Isn't 3.54's and 38" tires a little hard on the driveline? Seems like the trans would be lugging and working harder.
Old Oct 22, 2010 | 10:53 PM
Bencie's Avatar
Yea, and you probably would rarely get in 5th gear.
