350-400hp
350-400hp
I want to get 350 to 400hp out of my truck. Do y'all think that with some pump mods, a stage 4 upgrade from high tech and 190's or pod's those numbers can be reached? If not those injectors what ones do you think?
no you will have hard time reaching those numbers with those mods, your going to need turbo up grade, like a preformance 64 71 turbo with a set of 6x14 or 6x16 injectors, or even twins, i was supost to dyno on sat but they called it off do to broken dyno, but i have twins and 6x20s and a 12mm maxed out pump and im thinking only 450hp max max
We are talking about the 93, I don't have the 92 anymore. I wish I did. I am just curious cause I don't want to spend a ton of money on it, but I want to get atleast 350hp and run in the 14's. I guess that I'm gonna have to spend a little bit more money
If your gonna want to reach around 400 HP you going to have to spend some money. To keep my egts in range and still be able to tow and have a play truck i spent nearly 1200 dollars on a turbo alone. Total into getting my horsepower was around 4-4 1/2 grand to do it right.
BigDiesel396
Apr 2, 2008 07:35 PM
