IP install questions
I am putting a IP from another truck onto mine. I'm wondering if I need to do anything with timing the pump? Or do I just make sure the #1 cylinder is on TDC and line the keyway up and line up the marks? (I am going to going to advance it a little bit)
Line up your pump key in the slot in the gear. If you have a dial indicator, you can find your true TDC and do it right. If not, just find a good place and try it there. If you dont like it, move it.
Daniel
Daniel
sounds like im going to have to do it to mine to, timming is way off, like 2 or three teeth,
iv never done it like this before so you put number one to tdc and the the key for the saft should be at the top to, and if not spin the gear untill it is?
spooled142
Mar 19, 2009 09:10 AM
AndyMan
May 11, 2007 07:50 AM
QWKRTNU
Sep 26, 2006 10:22 PM
Paradise Racing
Mar 27, 2004 09:47 AM
