3200 spring in and working
Old Oct 3, 2007 | 07:31 PM
SmokemS's Avatar
i was just with ryan aka freew350 and he put in my 3200 gov spring and messed around alil bit with the pump.....truck runs great i can actually hit 100 but i would like to thank ryan for all his help and all his help later
ps that truck of his is amazing i never been in a first gen quite like that one man does that thing run
Old Oct 3, 2007 | 08:13 PM
Free89W350's Avatar
Josh thanks for the kind words and it was a pleasure doing the work. Like I said we'll have to get together later and get some more out of that magic little screw .
Ryan
Old Oct 3, 2007 | 08:33 PM
G1625S's Avatar
Hard to beat the bang for the buck of an early 1st gen
Old Oct 3, 2007 | 08:35 PM
COUNTRYBOY's Avatar
Where to get one?
Where can you get a 3200 spring? I'm thinking I need one, now that I have the fuel...
Old Oct 3, 2007 | 08:37 PM
G1625S's Avatar
ANY truck can benefit from the 3200 spring, regardless of fuel. To answer your question, any BOSCH dealer can get you the spring provided the part number.
Old Oct 3, 2007 | 09:26 PM
RumbleFish's Avatar
If you go to a pump shop, just give them the part number,. Don't explain what you are doing. When I tried to tell them what is was, they replied with a reaffiriming "huh?".
Old Oct 4, 2007 | 04:00 PM
I like the way the rear end actually picks up when he gets on it.
Old Oct 5, 2007 | 03:21 PM
SmokemS's Avatar
yea that was amazing never felt a truck do that before
Old Oct 6, 2007 | 04:26 PM
farmerzo's Avatar
I finally got my spring installed. Is it normal to gain 15lbs boost and a lot more power? The fuel pin is froze, I couldn't get it to move any. It also raised the idle 200 rpms with the idle screw set the same way as before. The engine will "runaway" now but I can't back the fuel screw out any cuz its stuck. Thanks, Alonzo
Old Oct 6, 2007 | 04:28 PM
Sounds like you ran the power screw in a little further when you put everything back together.
Old Oct 6, 2007 | 05:01 PM
farmerzo's Avatar
Thats what it feels like, but the power screw is froze in the pump. I couldn't move it in or out. It looks like somebody used thread locker on it.
Old Oct 6, 2007 | 05:02 PM
Then you have the throttle shaft clocked a tooth off. I say grind down the idle screw until it idles right.
hounddogks76
Aug 31, 2012 09:22 AM
92smokin blacky
Oct 3, 2010 07:21 AM
BurrisWill
Jan 25, 2009 08:23 PM
A-Poc
Apr 4, 2005 03:45 PM
papaw92
Mar 27, 2005 12:20 PM
