3200 spring
3200 spring
I put a 366 spring in a little while ago. Wasnt too impressed. Wasnt revvin out like I thought she should.
Found a couple things.
1: Pedal wasnt pulling the throttle lever all the way open. Fixed that by changing the holes of the ball as described a few threads ago.
2: Turned my pump 1/2 turn from runnaway. Was about 1 turn short. Didnt make THAT much of a difference in power from where it was.
NOW i see what everybody was talking about with the 366 spring. Fuels hard untill about 90km/h in 3rd. Havent tried 4th and 5th cause of the pyro.
Havent had a chance to look at the pyro cause its dark and I was too lazy to hook up the gauge lights... Will follow up.
All in all: she sounds saa-weet windin out! -6s have a nice sound revvin out
mine revs out pretty good without the gov spring and with just having the linkage set right so I get full throttle.
I do however have 2 important things on order and shipped. A DennT pin and that gov spring. One other notable mention in my eyes is the 14cm ex. housing that's on its way too. A notable mention because the stock one on my truck is the 21 cm housing. Those 3 items should wake things up. I'm just eagerly awaiting their arrival!
Just to throw a stick in the spokes here.
One thing you guys are overlooking is fuel pressure/flow. The stock lift pump is adequate at best on a stock truck. Anything over that and i'll bet even with new stock lift pump you pull your pressure down to ZERO!! And when that happens you loose your internal case pressure which causes you to loose injection timing advance which causes you to loose HP.
Aaron
Aaron
Aaron
Aaron
Aaron
Aaron
Thats good you mentioned that. I have a fuel pressure guage. I also have a newer lift pump(30k) and a WOT I cant get it to fall under 5psi, which I thought was the min. press. acceptable. Soon as the dutchess aint looking though, Its getting a low press. piston LP.
