3200 rpm spring install gone to heck
Old Jun 29, 2005 | 05:00 PM
fearthedeere's Avatar
OK now that we all know i dont know how to post pics got to Dens site and third pic there is a skinny spring towards the bottom that the one missing.
Old Jun 29, 2005 | 05:26 PM
pmtg's Avatar
Originally posted by fearthedeere
The broken one is the first spring under the 8mm allen screw on the throttle lever and the one missing is the spring on the throttle linkage that connects to the front of the engine[IMG][IMG]Governor_Spring_04-t[IMG][/IMG]
thats a fairly hefty spring to break. its the one that sits in the black plastic "cups", so to speak, correct? did it get twisted too much? where did it break?
did you check all around the engine compartment for the other spring? especially the lip that the oil pan is bolted to, lots of oily gunk that many items stick to and wont allow them to fall all the way to the ground.
Old Jun 29, 2005 | 05:53 PM
pmtg's Avatar
Old Jun 29, 2005 | 08:31 PM
nope the spring above that one.
Old Jun 30, 2005 | 01:39 AM
Bushy's Avatar
Patron Saint of 1st gens
I think you're referring to the breakover spring. You can call any Bosch shop and get it without too much trouble....
It's listed in the exploded view of pump as item #306- part number#1 464 651 430, "coiled spring".
While you're at it check the post on the plate that fits under it...it has a "post" that sits in the middle of those spring ends and it usually starts to wear thru over time..it is listed as:
..Item# 72- part # 1 461 901 489, "control lever".
Hope that helps ...
If pictures will help you can go here:
http://www.turbodieselregister.com/u...um&albumid=453
Look thru my picture gallery and confirm the items above.
pb....
Old Jun 30, 2005 | 09:39 AM
What would i look up in a phone book Bosch, pumps, fuel, im lookin and i cant find anything. Dose anyone have a phone number to a pump shop??
Old Jun 30, 2005 | 09:49 AM
Thanx bob it is that one break over spring now i just need a pump shop
Old Jun 30, 2005 | 09:56 AM
apwatson50's Avatar
just try to find any pump/turbo shop and they should be able to at least refer you to a shop. Around here the bosch shop is Central Motive Power.
Old Jun 30, 2005 | 12:05 PM
Tuckerdee's Avatar
Just call any diesel service shop (someone that works on big rigs and the like) and they should be able to refer you to a Bosch dealer/rebuilder for your parts. Not really in your area at all, but I've dealt with these people in the past: Wentland Diesel. Good luck.
Old Jun 30, 2005 | 12:19 PM
I called TDI in indy and got the spring 14bucks good lord but i gotta have it. so ill let yall know when i get then we can get this mess sorted out
Old Jul 1, 2005 | 01:16 PM
got the parts i need gonna finish the install today wish me luck
Old Jul 1, 2005 | 01:59 PM
How do you get that blasted spring back on. what were your methods. HELP!!!!!! Almost done just cant get it on
Old Jul 1, 2005 | 03:26 PM
HELP I cant rev past 1000 rpms and it wont idle. wft is wrong.
Old Jul 1, 2005 | 03:37 PM
Did you get the throttle shaft indexed wrong, or is the fuel screw backed out too far?
Old Jul 1, 2005 | 04:22 PM
prolly the throttle shaft is worng cuz my friend pulled it out. how do i fix it.
