2wd Front shock relocation kit?? Anybody...
Old Jun 30, 2005 | 11:10 PM
ouchman's Avatar
I guess I'm asking the same question in a different way.
Does anyone know of a front shock relocation kit for the D250 2wd? If not, where could they moved to - suggestions?
Old Jun 30, 2005 | 11:27 PM
Holsteinman's Avatar
Why do you want to move the shocks?
Old Jul 1, 2005 | 11:08 AM
Micaiahfied's Avatar
i think he wants to use some air helper springs in the front, but the shock is in the center of the coil.
Old Jul 1, 2005 | 04:22 PM
ouchman's Avatar
Yes, he does.
Old Jul 1, 2005 | 08:06 PM
smokNjoe's Avatar
why not use air shocks?
Old Jul 2, 2005 | 12:06 AM
loch's Avatar
I doubt that air shocks would fit through the spring if thats what you mean, iv seen a truck like that with airbags in the coils, ill try find a pic for you,,,why do you want to do this ?
Old Jul 2, 2005 | 12:33 PM
ouchman's Avatar
seems like a way to get the front end lifted while maintaining a comfortable ride.
Old Jul 2, 2005 | 09:23 PM
sho_shane's Avatar
I know I would love to lift my 2wd alittle
Old Jul 2, 2005 | 09:49 PM
frijoli's Avatar
why not go to a spring shop and get some taller springs? would that make the shock mounts too far apart?
Clay
Old Jul 2, 2005 | 09:56 PM
frijoli... i believe the 7226s springs are supposed to accomplish that. (i know ouchman used them on his last truck) some people love them and say it never sags again, i've seen other say they had to replace them. i think he (and i) are trying to see if there is another way to give some extra assurance that the springs won't settle back down.
Old Jul 2, 2005 | 10:31 PM
ouchman's Avatar
Actually drop-spindles would be the ultimate way to go, since you can only lift the truck so far with stock spindles.
When I lifted my '92 (no longer own it) they used 2" spacers AND 7226s springs. It was the worst ride ever. I LOVED the way the truck looked, but after a while it was just too much. I might as well have had NO shocks. I would like to find a way to lift a 2wd like my old one (5" front/3" rear) but still ride comfortably.
I wonder if lift spindles from another year truck would work?? Anyone...??
Old Jul 2, 2005 | 10:34 PM
ouch... what did you use to raise the rear in your other truck?
Old Jul 3, 2005 | 12:58 AM
loch's Avatar
i raised mine by new springs, ride is fine and after a year and half no sag,
but to answer your question i was informed his shock setup is patterned after an 87 chevy pickup, he no longer has the truck so pics are out.
Old Jul 3, 2005 | 12:00 PM
ouchman's Avatar
They used blocks.
Old Jul 4, 2005 | 09:51 AM
apache's Avatar
Years ago a friend had a 78ish D150 he was making a prerunner type rig. He dual shocked the front similar to a chevy 2wd is set up, putting the shocks in the back of the a arms and mounting to the frame above and also fabbed a brace for the idler arm. worked out pretty good.
freight train
22
Mar 25, 2013 04:46 PM
Fiftygrit
Jan 20, 2010 06:22 PM
stumpjumper
Aug 21, 2007 07:14 AM
ouchman
Jul 1, 2005 02:39 AM
angleiron
Sep 13, 2003 05:03 PM
