78 Ramcharger 2WD 12V build
Well I'm starting a build thats been in my head for a long time. I have a 93 Cummins crew cab that i'm using as a donor to make it happen.
As of right now i'm collecting parts over the cold months here in Michigan so that I can jump right in to it as soon as the weather turns. I do already have most everything from the donor to do it but I will need some guidance along this way from you seasoned builders.
Here is the rig that is getting the attention..
The current combo is a 400 with a 727 trans. Like the thread title says i'm dropping in an intercooled 12 valve between the rails. I will never tow with it I just want a fun truck to cruise and take to shows.
The cummins is attatched to a 47RH from a 94-95 truck and was looking for some advice about a trans crossmember. I am looking at a 89-90 3/4 ton diesel crossmember to swap in as the 78 one looks like it might not even be close to modifying to work with the newer trans. I am no stranger to fabrication of parts but thought this might be an option to save some time from having to build a whole new part. Any opinions on this?
This will be a slowly updated thread because it really won't start until spring but i'll post with parts I accumulate as time goes. I'll post pics of hhe donor truck as well (some of you guys might hate me for tearing that truck apart).
Anywho, thanks for any help and hope you enjoy the build as it goes.
Sweet ride!
Welcome to DTR
I will be following along. I see you found my similar build I aim doing on a 2WD Ramcharger too. I will be happy to help answer question as you move forward.
I have the 2wd diesel transmission crossmember if you end up needing one too.
Welcome to DTR
Thanks very much! Ya, I was super excited when I found your build thread because its pretty well exactly what I'm doing.with mine. I'm sure I will need to pick your brain a few times along the way so I appreciate that. Just by looking at pics of crossmembers I think the diesel setup might be my best option to start with. Let me know what you need for that one you have.
Thanks again!
I have a feeling any 89-93 2wd crossmember from a 6" frame will work. The one in my 90 D150 looks the same as my 89-90 D250 diesels.
I decided to go 8lug/4000# suspension on my '84 2wd ramcharger. Goes in easy. One of these months i may even finish it....
Oh man, that's a sweet looking RC! I like the soft top. Otherwise looks mostly stock still.
Much rust to deal with?
Do you have plans for the 400?
Thanks for sharing!
Thanks for sharing!
Here is the only rust on it (**** mice)
And here are a couple of pictures of the donor truck.
I hate to do it but I've owned it for around 13 years and its getting a little rough around the edges and its time for a change.
OK, so now you've started a whole nother tale! The '94 donor motor is in an '80s crew cab, what's the story on that? Did you do that conversion? Is the 400 going in there?
Sorry to be so many questions, but inquiring minds...
Welcome to the forum, I like the build you are doing and will be following but..... There really not that many crewcabs out there and unless it is a total rust bucket I personally would sell that (it might be ruff to you but someone I'm sure would love to have it) That should give you enough to get a good low milage 215 hp P pump and a good 47rh and any other parts you will need as well as some $$ in your pocket, it will also keep another Cummins Crew on the road.. JMHO
nothingbutdarts (10-30-2023)
nonrev (10-31-2023)
Jon Fanning
11-04-2018 02:07 PM
