1st gen piston LP will support how much HP?
Old Mar 8, 2008 | 03:15 PM
pwrtripls1's Avatar
How much HP will the 1st gen piston LP support? I want 350whp on #2 for a DD. I want to keep the whole setup as simple as possible.
Old Mar 8, 2008 | 03:23 PM
pwrtripls1's Avatar
I could have swore there was a reply here. Is somebody messing with me??????? Plus my PM sent box has been deleted and another post of mine was changed.
Old Mar 8, 2008 | 04:51 PM
stillsmokin's Avatar
You'll want to add high flow banjos from geno's, and 3/8 fuel line down the frame and through the sender to get better flow. 350HP or a little more is the area where you'll likely start run out of fuel pressure on the piston pump mod. It takes plenty of time, money and work to get there so have fun.
I can only get 12PSI@ idle out of mine now. Whole new fuel system going in this spring.
Old Mar 8, 2008 | 06:06 PM
I think you double tapped when you first posted?
https://www.dieseltruckresource.com/...d.php?t=195840
Either that or it's a glitch in the matrix warning you that the agents are coming and you should call for an exit...
Old Mar 8, 2008 | 07:03 PM
pwrtripls1's Avatar
If I some how doubleposted how did the first thread start at 10am and the other at 5pm. I think the man is on to me. I'm gonna go hide at WalMart.
wannadiesel
Dec 9, 2011 10:18 PM
PeytonMaterne
Aug 11, 2008 10:00 AM
pwrtripls1
Mar 8, 2008 09:29 AM
bgilbert
May 18, 2006 07:55 PM
