1st gen 2wd vs. 4wd steering box
Old Dec 17, 2010 | 11:03 AM
30dodgeboy's Avatar
I was told several years ago that the steering box used was the same for the 2wd and 4wd trucks, except for the pitman arm.
Is that true?
Is the pitman arm the same except installed rotated 90degrees?
My truck expertise is really with older Fords
Old Dec 17, 2010 | 02:54 PM
Wettstein's Avatar
Yes to both questions, and the 2WD box is mounted on striat to the frame and in a diffrent spot then the 4x4
Old Dec 17, 2010 | 04:49 PM
TIMMY22's Avatar
4x4 Bolts to a bracket that bolts to the frame.
Old Dec 17, 2010 | 05:04 PM
huntinguy's Avatar
The pitman arms are not the same. The hole for the draglink in a different size.
Old Dec 17, 2010 | 07:40 PM
30dodgeboy's Avatar
Thank you for the quick replies.
I appreciate the expertise
Old Dec 17, 2010 | 08:13 PM
PapeCAT's Avatar
1st gen '72 - 77 2wd have standard rotation, and 4wd have reverse rotation boxes.
1991.5 mopar
Feb 24, 2015 07:26 PM
93Fury
Mar 31, 2010 01:33 PM
Jordan5687
Feb 18, 2009 02:48 PM
doodah
Jan 15, 2007 06:59 PM
1320
May 6, 2003 06:30 PM
