1993 idle problems
1993 idle problems
I need some help! I recently put in a 366 spring and since then my idle is to high. The truck is idling around 1000rpm. I have tried to adjust the idle screw but the throttle is actually hitting the pump housing before it hits the idle screw. When i put the top of the pump back back together i made sure i lined up the index on the throttle shat correctly. Not sure what to do now. When looking at the throttle shaft and fuel linkage thebonly thing I can think of doing is changing the index on the throttle but not sure if that will change anything else.
Any help would be great appreciated
Rob
Rob
