1989 injector pump timeing advance
Old Jul 5, 2017 | 09:11 PM
shastaboat's Avatar
My mileage has dropped on my 1989 W350 when under load to about 12 mpg. I'd like to get back to 15-16 mpg when under load. I have installed a 47RH rebuilt trans and using toggle switches to activate the OD and locker. I have also installed an aftermarket intercooler. I tow in 3rd lockup at about 62 mph at 1900 rpm with the exhaust temp running below 1100. I've just had my pump set up and have good acceleration and horsepower. The mechanic said my pump was already advanced at 8 deg but I could go up to 12 deg. I recently replaced my injectors and just went a hair over stock, not even to the marine injector level. Do any of you have experience with the pump advance to 12 degrees? THANKS.
Old Jul 6, 2017 | 07:49 AM
1972RedNeck's Avatar
Did your mileage just magically drop, or did all of your listed mods make it worse?
Old Jul 6, 2017 | 08:12 AM
shastaboat's Avatar
over time
My mileage has dropped off over time and that is what has prompted me to replace the injectors and have the injector pump adjusted. I just had the pump adjustment done yesterday. I did the injectors 3 months ago. Also my throttle cable replaced yesterday which helped throttle response and the truck was idling at 1100 rpm. Now idling at 800 rpm. I haven't checked the mileage yet but am asking about rotating the injector pump while still attached to fuel delivery lines to 12 degrees advance.
ihboy
17
Jun 4, 2011 08:51 AM
mullishacrew
Aug 20, 2008 05:06 AM
Dumpster
18
Dec 17, 2007 12:49 AM
patheticfool
Nov 10, 2007 05:17 PM
goose2
Jan 10, 2006 08:04 PM
