195 thermostat
Old Aug 6, 2015 | 05:40 AM
csft's Avatar
195 thermostat
Anyone using a 195 thermostat in their first gen truck?
If so any part numbers?
I was hoping to have better heat this coming winter.
Old Aug 6, 2015 | 01:54 PM
Jim5870's Avatar
I've done it, cant recall the PN i used.
Even though it had a a 195, it would only to get up to 180 or so anyway.
I had to block off 50% of the rad with cardboard to start getting a temp rise above that.
Old Aug 7, 2015 | 12:13 PM
flyboy129's Avatar
I've heard the 195 does no better. In fact, because it is higher temp, it takes even longer to open up, meaning longer before heat. Fuel moving through the engine is what warms it. An exhaust brake would warm the engine up quicker. However, so will cardboard as stated. Plus, it's cheaper. Just don't tow heavy with it in place.
Old Aug 7, 2015 | 12:37 PM
j_martin's Avatar
Heater water is taken off the head before the t-stat, so it doesn't make any difference if it's open or not.
The reason that a hotter t-stat doesn't seem to make any difference is because water temp (within reason) isn't the problem. The problems are
1. Restricted water flow through the heater core.
2. Restricted air flow through the heater core.
3. Leakage around the bypass door used to regulate the heater temp.
To sort out 1 and 2, check the incoming and outgoing temperature. You can ir gun the fittings if they are not copper. copper doesn't radiate ir the same way that iron does. The readings are wacky. I digress, if their is a good difference between them, the water side is plugged. If both are hot, the air side is plugged.
These trucks do a wonderful job of collecting leaves, needles, and butterfly wings and piling them up against the heater core.
On another point, if you block off part of the radiator, either do it with a grill winter cover, or cut a round hole centered over the fan in the cardboard block. If you block part of the radiator, say the bottom half, the fan does come terrible flexing coming from the restricted area into the open. It can literally break the blades off the engine fan over time.
Old Aug 7, 2015 | 08:46 PM
Montana2x2's Avatar
How do you know this?
Old Aug 7, 2015 | 09:09 PM
j_martin's Avatar
Put a 1953 Chevy propeller through the hood.
coloblacksmoke
Jun 2, 2010 08:38 PM
Bookshelf
May 30, 2009 01:17 AM
dizzel
May 25, 2007 05:44 AM
schoust
Oct 18, 2006 11:31 AM
