195 thermostat
Old Oct 16, 2006 | 09:27 AM
schoust's Avatar
195 thermostat
Does anyone run a big block Chrysler thermostat in there truck?I looking for more heat for a vegi system I have setup and I have heard of people using this stat.Are there any cons to doing so???
Old Oct 18, 2006 | 08:09 AM
schoust's Avatar
Ok then if no one has tried this is there a thermostat that Cummins makes that is hotter than the stock piece???
Old Oct 18, 2006 | 10:18 AM
infidel's Avatar
My experience with CTDs is that the cooling system is so large it doesn't matter what temp the stat is, as soon as it opens the coolant temp will drop way low then climb again.
In other words there is an average temperature reached that stays the same no matter what the stat temp is.
Old Oct 18, 2006 | 11:15 AM
schoust's Avatar
Let me ask you this Bill have you ever heard of using the type of stat that I have referd to??Or do you think I would be better off just blocking the radiator off???
Old Oct 18, 2006 | 11:31 AM
infidel's Avatar
First time I've heard of changing the stat for your reason, most times folks are trying to overcome the normal cycling of the coolant temp. It doesn't work.
Blocking the radiator would probably result more in what you're after than changing the stat. Remember to leave a 6-8" hole in the middle of the cardboard or whatever you use and to cover the radiator all the way to the top, bottom and sides.
Be careful using the A/C with the radiator blocked, system can get too hot and over pressurize. The A/C is on when the system is in the defrost mode. Might what to consider this easy modification.
http://dodgeram.org/tech/repair/HVAC/Defrost_AC.htm
Removing the fan and using a winter front will result in the same effect as cardboard.
csft
Aug 7, 2015 09:09 PM
coloblacksmoke
Jun 2, 2010 08:38 PM
Bookshelf
May 30, 2009 01:17 AM
dizzel
May 25, 2007 05:44 AM
