17" wheels???
Old Dec 20, 2005 | 06:47 PM
tsmay51's Avatar
17" wheels???
Will the 17" wheels off the newer dodge trucks fit a 89 model ctd? I don't think they changed the bolt pattern. It is just larger in diameter. Please correct me if I am wrong... Thanks in advance...
Old Dec 20, 2005 | 07:50 PM
pwrtripls1's Avatar
yes they will fit. The ymoved to larger lugs but thats it.
Old Dec 20, 2005 | 10:55 PM
BearKiller's Avatar
At the present, the only way I would put 17" wheels on my truck is if they were given to me with a new set of tires on them.
LT rated 17" tires are still an oddity when you have one come apart and are a long way from home; they are not found easily even at large tire shops, let alone some little filling station out in nowhere.
Also, a 17" tire will cost about $50 more than a comparable 16".
In a pinch, used 16" tires can be found anywhere for $20 or so, and get you home without having to buy some un-matching new tire that will always be the odd-ball until it wears out.
You can about forget finding a used 17" because there just aren't enough trucks out there that are running them; and if you are fortunate enough to find a new one the same size, it will most likely be a different brand.
The reason for the larger diameter wheels is to make room for bigger brakes and sell more expensive tires.
Old Dec 21, 2005 | 06:24 AM
tsmay51's Avatar
farm truck
I agree with all that you have said. The only reason I want to go to a 17 is they are for a farm truck that is used to feed and make runs to town once in a while. The truck doesn't get 10k a yr. put on it. By the time it needs new tires I can go back to 16" or I am guessing in a couple yrs. 17" tires will be more plentiful and cheaper for these trucks. I also have an 03 model and it's crazy what some of the brands want for 17" tires. Yikes!!!
Old Dec 21, 2005 | 08:35 AM
pwrtripls1's Avatar
I'm not scared, if you decide you dont want those 17's let me know. I have 16.5's right now and it doesnt get any worse than that. I'd have better luck finding a tire shop in redneck-ville that stocks 22's than 16.5's.
Old Dec 21, 2005 | 07:00 PM
BearKiller's Avatar
I will totally agree with that.
16.5 tires, once common, are now rarer than hen's teeth.
Old Dec 22, 2005 | 05:15 PM
keithplacervill's Avatar
05 rims will not fit the rim hits the tie rod in front on 2 and 4 wheel drive i have tried it my self does not work the offset brings rim in too close
roughstock
Nov 2, 2013 01:48 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
VikingDiesel
47
May 11, 2007 12:52 AM
