14mm VE pump. Whats needed for the motor so ir can handle it??
I looking in putting a 14mm Ve rotary pump in my 92 W250 with an automatic. What do I need to do the driveline so it can handle it?
It would help if you put your build specs in a signature line. Go to User CP to do that.
I would like the truck to be a hot street truck its a W250, club cab, LE, auto. I have rebuilt he auto with a shift kit but kept the factory flex plate. The truck is bone stock. Would like to get 300-400 Hp out of my first gen.
I think Jason Sands 14mm is still running. I have heard of them lasting a while. The problem (as I understand it) is a fuel supply issue/cooling/lubrication issue.
Takes a big fuel supply to feed the 14mm head, and if you aren't running big, fat injectors with a supplemental fuel supply into the pump it eats itself.
JMHO.
Mark
JMHO.
Mark
that was the general understanding for a long time but I am not convinced that's the actual issue.
I'm wondering if it's a combination of a couple things. Rockentech not having perfect machine work and/or inferior metal being used. The 14mm H&R and the 4mm cam plate greatly increase the stresses on those parts afaik
The old KTA (I think that's who made them?) parts had better success but even those came apart.
If it were me, I would just ppump if you're after lots of power.
450 (and arguably more, a few have tickled the cusp of 500 on fuel only) can be made with enough effort.
300-400 isn't that hard to make on a stock VE if you know what you are doing.
