12cm hx35 housing?WG? 2000 cummins stock
I just did the 2nd gen 12cm/HX-35 gig on my 1st gen...in a 78 RC...it's a long story
check out reply # 14 -
http://ramchargercentral.com/index.p...,117914.0.html
No, the mounting braket is casted into the compressor housing, so the above suggestion is not possible. I can take photos if you need more clarification. My boost levels are controllable if I keep my foot out of it; I'd much rather have the peace of mind having the wastegate hooked up and set. I'll think of someway to mount the actuator. BTW the 12 cm is awesome, spool up is instantaneous.
I know the mounting bracket is cast into the compressor housing. The older style bracket (note totally different part bolted to housing) might still bolt on though. I think this is a valid question because when I have tooled around with 24V 12cm housings I had to source a missing actuator bracket and I bolted it in place with the supplied spacers and such. There were other mount holes that were not used still left on the exhaust housing.
ajbirken
Sep 6, 2006 12:11 AM
HOHN
Dec 7, 2003 02:07 PM
