10 or 13 speed
Old Jun 18, 2006 | 11:31 PM
BearKiller's Avatar
Originally Posted by Paws
Just told my old man about this topic and he said that there was an old 3spd brownie made by Spicer out there that is small and light enough to put behind the transfer case or transmission. He said that they were in the old Ford and Chevy 2.5 or 5 ton trucks. He thought that the number for it was a 5831, if anyone finds it I've got dibs on it . So keep you eyes peeled for any old farm 2.5 or 5 ton trucks sitting around.
I don't know about a three-speed; but, I happen to have a Dana 4-speed auxilliary, with two under-drives, a direct, and an overdrive.
If I don't go the 9-over route, I intend to put it in my truck.
This combo will give me twenty forward gears and four reverses.
Old Jun 19, 2006 | 01:43 PM
QIK2D's Avatar
we put a 3spd brownie style box in my old mans 90 f350. with the 4.10 gears it makes driving at highway speeds more liveable. don't know the gear ratios but it came out of a mid sixties chevy 2-ton flat bed. dont know yet if it was worth the effort (made all mounts, driveshafts, etc.).
Old Jun 20, 2006 | 12:10 AM
BearKiller's Avatar
Were you able to accomplish this without getting any driveline vibrations??
I am just itching to get this four-speed auxilliary in my Ford.
I don't have the shifter mechanism that goes with it.
I thought possibly one of the four-position Hurst shifters, that were designed to convert a three-on-the-column to a floor-shift, could be made to work for my application.
Old Jun 20, 2006 | 01:04 PM
QIK2D's Avatar
we mounted it about were the hanger bearing would be. kinda like a divorced transfer case. this is a two wheel drive vehicle. dont think i'd attempt on a 4wd. it has a harmonic vibration (not bad, but there) from around 40mph to 50 or so. i think its due to driveshaft angle from the box to the rear axle. old man said he can live with it so we went no further. btw, this is not a job for the timid or non-mechanical. lots of fabbing brackets and mounts.
Old Jun 20, 2006 | 08:18 PM
BearKiller's Avatar
This sounds like most of the things I get in the middle of.
I take it you were able to eliminate the carrier-bearing.
How long is the shaft between the transmission and auxilliary??; a good guess is close enough.
Did you leave the speedometer as is; or did you run a new one to the port on the auxilliary??
My truck is a very long wheelbase, 2WD, F-350.
Thanks.
Old Jun 22, 2006 | 04:22 PM
QIK2D's Avatar
man, sorry no answer for a few days (had to work at work, kinda sucks ) . the carrier bearing is gone, short front shaft, maybe 12-14 inches. old man used a rear shaft from a std cab(still had it shortened). the box is bigger than most would think. left speedo untouched, incorrectness varies according to gear choice . shifter linkage was the biggest pita of all. wanted to bind, couldnt get it to operate consistently. finally rigged a cable set up of a late model car. 3 positions straight line shift
faster_than_ford
33
Mar 5, 2004 07:24 PM
Sonny
Feb 15, 2004 11:47 PM
SilverDodge
Feb 2, 2004 05:56 PM
Mrcummins24
19
Oct 1, 2003 11:43 AM
KC
Jan 10, 2003 11:25 PM
