Is the 03-04 stock turbo (HE341) a good upgrade?
Old Feb 28, 2009 | 12:12 PM
rich's Avatar
i used the turbo off my 03 when we put a 12v in the 03 truck it would spool up fast but would get higher egts faster
Old Feb 28, 2009 | 12:33 PM
The_Head's Avatar
I wonder if the "acceleration" of the EGT's matter, or is it just the maximum value that matters to us.
Old Feb 28, 2009 | 01:32 PM
soggy's Avatar
Sorry, i have a 341 on my pickup now. You have to remember also that the whole system from turbo to the engine is much less restrictive on the newer trucks.
Old Feb 28, 2009 | 01:38 PM
The_Head's Avatar
My bad, I realized after I replied that you had the thread on cumminsforum.
Old Feb 28, 2009 | 01:44 PM
Ace's Avatar
Ace
Originally Posted by soggy
...remember also that the whole system from turbo to the engine is much less restrictive on the newer trucks.
That's an excellent point. The heads flow better and the exhaust has wider bends up front with the low-mounted turbo. The 12v has to work harder (flow more air) to hit the same EGT points. Our '07 seems to run very similar boost and EGT points as the '91.5 across the rpm range - same size compressor wheel, full 4" exhaust on both trucks. But the 9cm housing on the new truck spools instantly, while the 12cm on the 91.5 spools quick it's not that quick, delivering about the same boost/EGT numbers across the board.
Old Feb 28, 2009 | 04:00 PM
The fuel system has a lot to do with it, too. Much tighter control over fueling and timing.
bmeyer2
0
Aug 30, 2011 10:06 AM
bemhoff
Jul 13, 2011 05:58 PM
Flatbed24v
Aug 29, 2009 11:10 PM
Big Blue24
Nov 27, 2008 12:36 PM
Bowser50
Nov 8, 2008 12:34 PM
