Piston Lift Pump Install
Old Oct 20, 2006 | 02:03 PM
  #31
flashgordon's Avatar
Cool, so i guess the dodge dealer is the only place that has discontinued the spacer.........right?
Old Dec 29, 2006 | 06:24 PM
  #32
tomd's Avatar
Thumbs up
I had no problem finding all the parts at Cummins located in San Leandro Calif. They had everything, including the spacer. All the same numbers.
This thread was helpful. The pics were very much needed in order for me to understand the carving needed etc.
I have my new piston pump installed in my truck now.
Best Regards,
Tom
Old Feb 11, 2007 | 05:08 PM
  #33
Updated part numbers courtesy of Boatnik:
Code:
Description              P/N        Qty.
Pump, fuel transfer   3936320    1
Tube, fuel supply     3914753    1
gasket, Cover Plate  3939258    2
Spacer,Mounting      3914284    1
washer, sealing        3963983    2
Old Mar 12, 2007 | 11:24 PM
  #34
BearKiller's Avatar
Angry No Pictures
Where did all the nice pictures go??
Thanks.
Old Mar 12, 2007 | 11:51 PM
  #35
BC847's Avatar
1st Generation Admin
Uh-Oh!
Me and Dave have been moving images around to make room for the starter rebuild thread. I guess we missed something.
Give Dave a chance to mess with it as I'm sure he can get it sorted out.
For the moment, go to the 1st Gen tech pics to see them there in my folder ~ https://www.dieseltruckresource.com/...ry.php?cat=522
Old Mar 13, 2007 | 05:43 PM
  #36
Yep, I messed it all up. I'll get it squared away soon, keep yer shorts on.
Old Mar 13, 2007 | 06:33 PM
  #37
Pix fixed on this one, I'll be working on the others shortly. Thanks for your patience.
Old Mar 14, 2007 | 04:58 PM
  #38
There have been several questions regarding the thickness of the spacer plate. According to Alec, it is 3/16" thick. If you are handy with a torch and a drill press you can make one out of flat stock.
Old Apr 20, 2007 | 10:46 PM
  #39
BearKiller's Avatar
Arrow New Part Numbers
I just got back from the Cummins store.
There are some up-dated numbers for some parts of the piston-lift-pump project.
The pump, itself Old Number = 3936320
New Number = 4944714
Cover Plate Gaskets Old = 3931348
New = 3939258
Banjo Washers Old = 3918191
New = 3963983
So far, the spacer is still # 3914284
I didn't need the new hard-line, as I am running the fuel-lines differently.
These part numbers are good as of Friday, April 20, 2007.
Old Feb 27, 2008 | 07:25 PM
  #40
krazykarl454's Avatar
so how much does the lift pump cost at the cummins dealer?
Old Feb 28, 2008 | 01:46 PM
  #41
bgilbert's Avatar
Cummins ~$170, Case/NH ~$130.
Old Aug 23, 2008 | 01:50 AM
  #42
winkdemon's Avatar
awesome ,, how to ,,, thats the way they should all be ...
Old Aug 23, 2008 | 10:41 AM
  #43
SkinnyBTN's Avatar
Thanks for the measurements Wanna and for the write up BC! Gave me the motivation to get started on mine. There is a pump on Fleabay that I'm thinking bout purchasing, but it says it will replace 3936316 or fp916 does anyone know if this sound OK. Also one with a part # of 4988747, Thanks!
Old Oct 8, 2008 | 08:37 PM
  #44
sdubfid's Avatar
The pump number has been changed again. It is 4988751 as of October 08, 2008.
I must have gotten really ripped off or they severely jacked the price up as I payed $285 for this pump directly from cummins.
After taxes and the spacer/gaskets/fuel line and washers/fuel filter my bill was $425
Old Oct 8, 2008 | 10:07 PM
  #45
Fergavs's Avatar
Ouch! Thats alittle much, you could have almost done a AirDog100 kit for that price. Plus you would have got the other stuff aside from just a fuel pump. I think they gouged ya.
