Yep, another tick tick question
Old Jan 10, 2006 | 09:12 PM
DZLPWR's Avatar
Okay guys,
Got the ol' tick tick going on under the hood. Sounds best warm when between 1000-1600 rpm under no load, just slowy crusing in 2-3 gear, and at idle. Ticks steady with rpm.
My OF valve is 1.5 years old, fuel lines are all rubber, 1 year old, and did a valve adj. 2 weeks ago. Can hear it best listening at driver side wheel well. Fuel filter is over due for a change. May cause it?
Im guessing my lift pump needs replacement from reading the previous tick tick threads? Im just asking your opinion on what i should do. Investigate more? I just dont want to throw parts at it hoping to fix a prob . I just spent a sat. replacing rear shoes(RR axle seal leak a while ago, oily shoes never got replaced) and doing a valve. adj. to fix pulsating brakes and a ticking sound. Only to find out my front rotors are warped and my valves were pretty much in spec and the tick did not go away. Im just trying to avoid that again . Any help in what direction to go would be most appreciated. TIA -Jake
PS: Oh yea, my doors are rusty, clutch slipping(my fault), wipers have a mind of there own, oil pr. gauge likes to scare me and say 0 for a sec, water in cab, front tires like to wear funny, oil loves to seep out of front vac/PS mount, turbo is flicking me off at 40psi, BHAF looks kinda black from soot, and im still trying to figure out my next step towards twins Oh i love it
Old Jan 10, 2006 | 10:34 PM
smokin habit's Avatar
while truck is running push in on manual fuel pump on the lift pump when my lift pump started ticking this is how i found out what it was the tick was steady with the pulse of the pump changed pump and the tick left
Old Jan 11, 2006 | 04:44 PM
DZLPWR's Avatar
Sorry smokin habit, im not following you on what is supposed to happen when i push in the primer button?
Old Jan 11, 2006 | 05:24 PM
Equipment man's Avatar
if you press on it while the truck is running, you will hear the tick go away.
Basically, it is a clogged fuel filter. but smokin's idea helps you be sure of that
Old Jan 12, 2006 | 04:12 AM
you just barely push in on it and everytime the pump actuates you will feel the primer button pulsate if the tick is in time with pulsating the lift pump is goin out hope this cleared that up
Old Jan 13, 2006 | 06:00 PM
DZLPWR's Avatar
Oh okay, thanks for the input guys. That will help get me in the right direction. Thanks-Jake
Old Jan 13, 2006 | 06:07 PM
mr T's Avatar
check ur belt too
MTC
Jan 2, 2008 07:53 PM
stirpicult
34
Nov 15, 2007 08:50 PM
59FORD
Aug 10, 2005 08:09 AM
haulywood
Jun 10, 2005 11:27 PM
OHFarmboy
Dec 27, 2003 11:36 PM
