Where to put bypass filter?
Old Apr 17, 2006 | 09:26 AM
Red's Cowboy's Avatar
I am expecting my Amsoil bypass filter unit to arrive any day now. Does anyone have any advice or recommendations on the best location to install this unit? Fabrication of the mounting hardware should not be a problem.
As always, thanks for the great help!
Old Apr 17, 2006 | 09:54 AM
infidel's Avatar
I made a bracket that shares the passenger side battery hold down bolts.
Have seen others use the area at the far back driver's side corner under the hood but this only works on rigs that don't have 4 wheel ABS
Old Apr 17, 2006 | 01:36 PM
Greguw's Avatar
Smile Re : Amsoil
I have the same set-up ...I made a mount and moved mine to an area just about the middle of the truck cab on the passengers side , if you look where the floor comes up to the hump .
I made a mount off the frame and a little shield to guard from rocks . For me that worked out perfect , I also have a mounted a remote full size trans filter right off the front support ... just under the rad...Thats a good place too ... just don't forget a sheild .
Hope this helps
Greg
Old Apr 17, 2006 | 04:41 PM
rharveysr's Avatar
What about a location for us twin turbo guys... There is not enough room with the filters on the battery and the intake tube on the BHT3B...
I am running the towing twins from PDR and there is NOT enought room for the tube to make the bend with the filters there...
Rick
Old Apr 17, 2006 | 07:29 PM
Dieseldude4x4's Avatar
I mounted mine here on the core support.
https://www.dieseltruckresource.com/...cat=500&page=2
Made up this gaurd of stainless.
Probably won't suit everybody but works very well for me. I can change both filters in about five minutes.
Old Apr 17, 2006 | 08:50 PM
Mess?
Infidel,
I like the idea of having the filters right up where you can get to them without crawling under the machine, but what about the mess factor? How difficult is it to change the filters without spilling, splattering, etc all over that area of the engine compartment?
Old Apr 17, 2006 | 09:00 PM
spitfire9137's Avatar
Just put a plastic grocery bag around the filters before you take them off. Make sure it don't have holes in it though.
Old Apr 17, 2006 | 09:11 PM
HaulinBut's Avatar
Wow....kinda amazed with the size of oil lines used for a bypass filter! If I ever figure out how to post the pics of where I put my Frantz, I will post them, but I tucked mine behind the extreme rt. corner of the bumper. Very protected, and yet easy to change. Also, when I changed it the other day, it takes about 20 seconds to have the canister removed and there is very little oil that drains.
Old Apr 17, 2006 | 09:23 PM
I thought about that just when I hit the "Post Reply." Good answer!
dmill
Apr 5, 2011 02:26 PM
barngal6
Jul 5, 2009 06:49 PM
VinDiesel
Dec 3, 2002 08:06 PM
VinDiesel
Nov 8, 2002 09:22 PM
