Where to get a 1995 PCM
Old Apr 27, 2012 | 05:36 PM
Tobin's Avatar
Anyone know a good inexpensive place to get a PCM for a 1995? Once this heats up a little, the tach stops working, won't go into OD, no cruise, no A/C, and it stops charging.
No one seems to have a PCM available for the 94/95.
Thanks,
Tobin
Old Apr 27, 2012 | 06:53 PM
TxDiesel007's Avatar
rebuild perhaps
check on ebay.. or the ***********..
Old Apr 27, 2012 | 06:58 PM
infidel's Avatar
Good luck, it's hard to find an inexpensive one.
Junkyards have been striped of them.
Dealer can get you one for $700.
I would try ebay. Remember you need one for an automatic only.
You're lucky though, '94 and '95 are the only years that are interchangeable.
Old Apr 27, 2012 | 06:59 PM
patdaly's Avatar
Thanks,
Tobin
No Tach, all those things won't work, probably not PCM, figure out why tach signal is lost.
Start with the simple stuff, check air gap, connections, wiring all the way to the PCM.
Old Apr 27, 2012 | 07:03 PM
infidel's Avatar
Old Apr 28, 2012 | 07:41 AM
Tobin's Avatar
I'll check the air gap but she works fine until it gets a little warm under the hood and she stops working. I even put the PCM in the other 95 and it did the same thing.
Tobin
Old Apr 28, 2012 | 10:02 AM
patdaly's Avatar
Tobin
Ok, then it probably is the PCM then, weird mode of failure though, they usually die totally.
One reman on Ebay for 95 with Auto, 300 bucks guaranteed, provide mileage and VIN and it is programmed, can't post the exact link, but it is seller bmwsalepro.
Also available at Rock Auto......http://www.rockauto.com/
Old May 6, 2012 | 05:21 PM
Balzac's Avatar
Check Auto Zone, have re-man for $199 to $265 1 year guarantee.
I have the same problem, put new cummins speed sensor and now the same problem when cold.
Old May 7, 2012 | 11:24 PM
Mark Nixon's Avatar
Be careful with the '94-'95 automatic ECMs.
Back in the day, they were known for having problems that caused the overdrive to randomly dis-engage.
The fix was Chrysler superceding the OEM module with an updated one (Technically an "unofficial Recall").
There are still some of the old part numbered ones floating around out there.
I used to have the OEM part number and Googled it once and came up with comments like I outlined above.
Mark.
Stamey
May 27, 2012 06:39 AM
Big Perm
Dec 18, 2007 08:44 PM
Boatnik
Mar 22, 2007 08:35 PM
greasy
Apr 21, 2006 11:36 AM
