where to drill for probe?
Old Oct 26, 2006 | 11:53 AM
somis13's Avatar
I want to have my exhaust manifold drilled and tapped for my egt gauge and the guy thats gonna drill it asked me if it was a divided manifold, so that is my question to you. how will I know if its divided without taking the turbo off?
and does any one have a picture of a manifold with the probe in it that they will share?
Old Oct 26, 2006 | 11:58 AM
Brendan's Avatar
My probe is in the small intermediate cast section just before the turbo, I think that's the best place for it. You should pull the turbo off to tap the manifold anyway, but it should be one piece anyway.
Old Oct 26, 2006 | 12:11 PM
plow's Avatar
http://www.tstproducts.com/pdffiles/instpy25b.pdf this is your manifold with the probe pre turbo it is divided 3 and 3 probe should be drilled in center.
Old Oct 26, 2006 | 12:25 PM
crobtex's Avatar
Mine is a 24v, but this is where it is.
Old Oct 26, 2006 | 01:22 PM
displacedtexan's Avatar
Mine is in the same place, and it is not necessary to remove the turbo, I didn't, many others haven't either, just clean the shavings out, and the few that remain will just blow through on startup.
Old Oct 26, 2006 | 03:32 PM
somis13's Avatar
thanks I've just finished the install as the tst guidelines show. every thing is good, now what are average egt's on a stocker supposed to be? I get just over 1000 on flat ground. w.o.t. up to 75m.p.h.
Old Oct 26, 2006 | 06:26 PM
JKM's Avatar
JKM
That does not sound too unreasonable. my stock temps in the winter time topped somewhere around 900, if you idle it long enough it should dip down somewhere around 250.
Bombed , my temps get as high as 1400 , and it still will idle down to around 250.
Brian08Q35004x4
Feb 1, 2011 04:37 PM
mega_man
May 29, 2008 03:40 PM
Tim Frederick
Oct 6, 2007 02:09 PM
DanMan
May 5, 2007 03:00 PM
Drafter
May 10, 2003 10:51 AM
