When to replace injectors?
Old Oct 15, 2008 | 02:30 PM
66gaza's Avatar
I finally got round to getting the injectors pop tested they have 150K on them so I was just making sure they were OK. The spray pattern was fine and none of them dribbled but the pop off pressure is supposed to be 260 bar and they were all just under 240 bar. Will this make them pop early and in effect increase timing? What difference will the 20 bar loss in pop off pressure actually make? So at what point is it adviseable to replace or rebuild the injectors? I was told it would cost me about $20 to get each injector sonic cleaned and have the pop pressure put back to 260 bar has anyone had this done and was it worth the effort? they quoted me silly money to totally rebuild them, about the same $$$ as some new DDP2s. This is for a commercial 6BT engine. Many thanks for any info.
Gaza
Old Oct 15, 2008 | 06:34 PM
infidel's Avatar
I've read that just having the inlet pressure to the injection pump too high will effect timing so it follows that too low pop off will do the same.
As far as percent of normal before it matters I don't know.
I had the injectors on one of my JD tractors adjusted back up to the recommended pop off but it was because some were quite different than the others. The JD tech told me it didn't matter much if the pop off pressure dropped some, most important was that they were the same.
Old Oct 15, 2008 | 08:13 PM
BigDiesel396's Avatar
I would have to agree with infidel, 'specially the last statement. I would think it would be more important to have them all the same then exactly at 260. Although there would have to be a limit to how far they sink to where you need to rebuild/replace.
Old Oct 16, 2008 | 09:07 AM
Dartmouth 12V's Avatar
The actual pressure having dropped around 10% is not a huge deal but it does have some effect. The higher the pressure, the more precise fuel control you get, the lower the egts, and the better your mileage. However, this effect is quite small. I would not worry too much about it for a while, then at some point get the injectors that you want.
The pressure is only part of the equation. As the injectors get older, the holes actually get larger and they flow more fuel but it is less precise. There are people who have gone over 500k on original injectors and what they find when they put a new set of stockers in is that they have significantly less power but also much better fuel economy.
Old Oct 16, 2008 | 01:55 PM
66gaza's Avatar
That might explain why I can get 27lb of boost when the only fuel mod I have is to move the afc forward.
Gaza
Old Oct 16, 2008 | 02:13 PM
shorthair's Avatar
I believe 1 bar is 14.7 psi at sea level so 20 bar should be 294 psi could make a difference no ?
Old Oct 16, 2008 | 07:06 PM
infidel's Avatar
Percentage wise (7.8%) 290 psi isn't much compared to a normal 3770 psi (260 bar)
How much difference it makes I don't know.
Old Oct 16, 2008 | 08:48 PM
heykw's Avatar
I would guess it would b about 7.8% difference.
Old Oct 17, 2008 | 03:57 PM
66gaza's Avatar
Would my mileage increase by 7.8% if I replaced them with new OEM sticks?
Also when people say they got a 1-2mpg increase from say fitting DDP2s is that from old injectors to new DDPs? as thats not comparing apple to apples.
Gaza
Old Oct 18, 2008 | 11:14 AM
There are two factors in mileage if you assume identical injector design. The first is pop-off pressure. The higher the pressure, the more precise the fueling. Pressure and fuel economy are not linearly related. In the example above, I doubt the mileage gain from changing the pop off pressure would be anywhere near 7.8%.
The other factor is the holes and how well they atomize fuel. DDP's website actually has a pretty good explanation of it. The bosch injectors are pretty good but have a rough edge which is where the ddp's do better. The cleaner the hole, the better atomization you will get.
rguerra01
15
Oct 28, 2009 05:16 PM
High Plains
13
Oct 15, 2009 06:16 AM
Hillbilly Delux
54
Jul 5, 2009 07:15 AM
KRB
May 20, 2007 06:20 PM
BIGOKIE
Jul 21, 2004 05:53 PM
