What's Your Fuel Filter Interval?
Old Apr 27, 2009 | 05:18 PM
bigfatricky's Avatar
'95 12v auto 4x4, 208,000 miles.
Changed out my fuel filter last fall after experiencing delivery symptoms, and it completely solved my choppy/low power issues. Used a Wix. Started getting similar symptoms recently (a little jolt every few seconds at 75mph, died when stopped but started again and would run without high fuel demand) so I changed it out again. How often do y'all change fuel filter? I only put on around 4000 miles since the last change, so it seems a bit premature.
I have run some biodiesel in warmer weather, but only a small amount as a lubricity enhancer. Only used powerservice for the winter, no biodiesel.
Thanks in advance!
Old Apr 27, 2009 | 06:38 PM
infidel's Avatar
I go by my fuel pressure gauge.
When the highway cruising pressure drops 4 psi I change it.
12 valve, this is a drop from 32 to 28 psi.
Usually go 40-50k miles.
Fuel pressure gauge will pay for itself by just eliminating one needless filter change, every diesel engine should have one.
Going by mileage is nothing but a guessing game. One dirty tank of fuel can clog the filter in ten miles.
On the other end of the spectrum I've run into two filters that came with the truck when new, had over 100k and were still fine.
It depends entirely on where you pump your fuel.
Old Apr 27, 2009 | 09:26 PM
DU.DP.'s Avatar
i agree with infidel. i do mine every 5000 or every oil change but when i get guages i am putting a fuel pressure guage in also, i think i will go off that from now on after reading this...
thanks david
Old Apr 27, 2009 | 09:40 PM
carl48's Avatar
infidel is correct this is the very best way. the filter filters better the dirtier it gets and most are throwing them away about the time they start to clean better.
Old Apr 27, 2009 | 10:40 PM
J.Suplanski's Avatar
Talking fuel filters
Every 6,000 with out fail!
Old Apr 27, 2009 | 10:47 PM
seahawkdodge's Avatar
You might have some crap in your tank that got stirred up, or a bad tank of gas... I change my filter about once a year, using a Wix or Fleetguard.
Old Apr 27, 2009 | 11:00 PM
Swarthy Dago's Avatar
I have two, one on the block (stock) gets changed about every 20k and the aftermarket one gets changed about every 10k or when I lose pressure. my pressure is usually 20 to 27 psi
Old Apr 28, 2009 | 08:01 PM
FATCAT's Avatar
I change my oil and fuel filter at the same time ... every 5,000 miles.
They are cheap and it is cheap insurance
Old Sep 3, 2009 | 07:34 PM
kandgo's Avatar
Man! I wished I had you all's money to change my oil every 5k miles???
Old Sep 4, 2009 | 08:05 AM
patdaly's Avatar
Eh, it isn't expensive if you recycle your old Rotella.......into the tank.
bigfatricky
15
Apr 28, 2009 09:34 PM
nooska
Nov 12, 2008 02:01 PM
tristan21
Sep 11, 2007 09:37 PM
FOXY005
38
May 19, 2004 04:02 PM
Nevada
Nov 24, 2003 10:27 AM
