what is a dump valve
Old Oct 12, 2006 | 10:15 PM
silkmanilla's Avatar
i know what it is and when it is open i smoke more but, looking for more info.
Old Oct 12, 2006 | 10:48 PM
oh come on lend some help
Old Oct 12, 2006 | 11:50 PM
displacedtexan's Avatar
Give things a little time...
An exhaust dump? Allows you to dump te exhaust (usually right after the downpipe) so you can have a muffler for normal daily driving, and run open exhaust if you want.
Old Oct 13, 2006 | 09:32 AM
clutch1's Avatar
If you smoke more then maybe your talking about some kind of blowoff valve.
When its open then you build no boost therefore no proper air to burn fuel.
More smoke.
Old Oct 13, 2006 | 10:03 PM
could bewrong on description. it is located beside the brake booster and u use an allen wrench to remove the cap there is a spring in it and a threaded adjuster.
Old Oct 13, 2006 | 10:16 PM
The starwheel in the AFC housing. It controls the fueling pre boost, under about 3 psi. Loosening the starwheel increases fueling, smoke and helps the turbo spool quicker.
Is that what you were wanting? Let me know, I will try to help as much as I can.
Old Oct 13, 2006 | 10:21 PM
awsome, is there any way besides trial an error to find the best setting
Old Oct 13, 2006 | 10:34 PM
Not really, what works well for me may not be what you want.
FWIW- The holes that bolt the AFC down are slotted, I have my housing all the way forward, and then I tightened the starwheel (starting with it pretty much all the way loose) untill the smoke was acceptable. I like being able to drive normally with not much more than a haze. Hope that helps you get yours set up. Tinkering is the fun of owning a 12v
Old Oct 13, 2006 | 10:41 PM
exactly the way i feel about the smoke, pull an alluminum cattle trailer and don't want it to turn too black, owning a 12 is the greatest except for the brentz i get on monday wow my check book is crying. thanks for help
Old Oct 13, 2006 | 11:02 PM
Glad I could help. I remember being the new guy, and having Rick help me get things figured out on my truck... It's nice to be able to return the favor. And welcome to the DTR family.
johnny5.9
May 7, 2015 10:43 PM
capt.Ron
Feb 25, 2014 07:52 PM
halerazor
Sep 13, 2004 04:46 PM
thumbs
Aug 6, 2003 12:39 AM
