What does white smoke mean?
Old Mar 24, 2005 | 09:25 PM
boostedte37's Avatar
Hate to ask but what exactly does or is the white smoke? I have read that black smoke is unburned fuel is that accurate
Old Mar 24, 2005 | 09:32 PM
phox_mulder's Avatar
White smoke is also unburnt fuel, but for other reasons.
Main reasons are cold combustion chamber and retarded (or advanced?) timing.
Black fuel is unburnt due to not enough air to fully combust,
plenty of heat though thus the "soot".
phox
Old Mar 24, 2005 | 11:30 PM
BoostdCTD's Avatar
You were right Phox, to far retarded is white and to far advanced is black smoke.
White is unburnt due to lack of combustion temperature, black is due to insufficient air.
Old Apr 19, 2005 | 08:25 PM
matador's Avatar
Mine is smoking a whitish blue smoke after startup, sometimes for 10 to 20 minutes if I let it idle. If I drive it it dissapears sooner. SOmetimes it seems quite a bit worse than at other times. I checked timing and that is ok. I just had my one yr old injectors out and cleaned and reset and it still does it.
I checked the rubber fuel lines and they seemed fine also.
Can the injector pump be the culprit and how do I check that out with it on the truck?
any suggestions?
Old Apr 19, 2005 | 10:14 PM
Hemi Cat's Avatar
If you advance your timing some, 16-17, the white smoke will go away and run better and get better fuel economy.
Old Apr 20, 2005 | 10:17 AM
infidel's Avatar
matador, your truck sounds normal, it just isn't warmed up enough for complete combustion. Idling a cold engine won't warm it up, in fact it can get colder. Get in and drive.
Old Apr 20, 2005 | 02:26 PM
greatwhite's Avatar
Re: What does white smoke mean?
White Smoke = New Pope, Hence the term: Holy Smoke
No, Black Smoke = NO New Pope
Sorry, I just had to.
Old Apr 22, 2005 | 05:36 AM
B-rock's Avatar
thats funny, no thats funnay!!! hehehehe
DOZENVALVE
Oct 23, 2013 06:42 AM
tunaman
Aug 20, 2008 08:59 AM
Crabjoe
Dec 2, 2006 09:14 PM
D.Wiggs
22
Nov 7, 2006 04:20 PM
Journier
Oct 28, 2005 11:13 AM
