White Smoke, Does the TSB Help?
Old Nov 6, 2006 | 04:42 PM
D.Wiggs's Avatar
Hey guys,
All of a sudden, I am getting alot of white smoke from my truck; even when I have had it plugged it and even after it is warmed up and been running. What exactly is the cause of the white smoke and does the TSB flash really solve the problem? Is there anything else that I can do to eliminate the problem. The black smoke I like; but the white smoke is embarassing. I feel like I am driving some 1970 Dodge Dart!
Any help is appreciated!
Old Nov 6, 2006 | 06:24 PM
XLR8R's Avatar
It's not water (coolant) is it?
Old Nov 6, 2006 | 08:05 PM
D.Wiggs's Avatar
You mean I don't have enough, or am burning it? I have checked all the fluids and levels when Iw as making sure I had the engine heater cord about 4 days ago.
Old Nov 6, 2006 | 08:17 PM
XLR8R's Avatar
Just making sure you don't have a HG issue...
Old Nov 6, 2006 | 08:19 PM
P.J's Avatar
P.J
As in, steaming it off out the exhaust......
How much are we talking here? Does it go away once fully up to temp.?
Old Nov 6, 2006 | 08:35 PM
D.Wiggs's Avatar
Let's say on a scale from 1-10 the white smoke is a 10 at cold start and low idle. It mostly goes away if you can get the idle up to 1500RPM or more. Once up to temp the smoke does not come back unless it is sitting in low idle or when first engaging a gear (e.g., 1st, 2nd, Rev.)
Old Nov 6, 2006 | 10:13 PM
XLR8R's Avatar
Sounds like the white smoke flash is in order... make sure the dealer doesn't flash anything else unless you OK it first!
Old Nov 6, 2006 | 10:24 PM
D.Wiggs's Avatar
Do you think it is dirty injectors or what? I don't know what causes white smoke.
Old Nov 6, 2006 | 10:27 PM
XLR8R's Avatar
Do you run any fuel additives?
Old Nov 6, 2006 | 10:28 PM
D.Wiggs's Avatar
No, never knew what to run.
Old Nov 6, 2006 | 10:43 PM
53 willys's Avatar
I thought white smoke = Cold engine OR blown head gasket???
Old Nov 6, 2006 | 10:44 PM
XLR8R's Avatar
and how many miles on your rig?
Old Nov 6, 2006 | 11:06 PM
XLR8R's Avatar
Sure - it can, but there was a TSB on the (early?) '05s for white smoke at start-up & idle... mine did it a few times until I got religion with PS.
Old Nov 6, 2006 | 11:18 PM
D.Wiggs's Avatar
I have 2900 miles.
Old Nov 6, 2006 | 11:53 PM
XLR8R's Avatar
With all of your power bombing, I'd expect HG issues, but...
Since your white smoke only occurs at start-up & idle - I think your fueling mods may be exacerbating the white smoke TSB issue. Have you worked your truck HARD with those mods? I would definitely run silver PS through it - can't hurt anything!
p.s. don't forget - you're far from broken-in
