what do I have? help
Old Jan 21, 2008 | 05:01 PM
Jreif80's Avatar
ah yeah locking hubs are great the conversion is where you change your factory hubs (electric or however they are) I believe my 06's hubs are always lock but I'm not sure anyways you change your factory hubs and convert them to manually locking hubs like older 4x4's had on them where you get out and lock your hubs at the hub. I can't remember how my old 98's hubs were from the factory but if 2nd generations are like I think my 06 is where the factory hubs are constantly locked you probably will see a slight increase in mileage. I think with 2nd gens it's more about reliability and cheaper replacement parts (berings and seals) than factory units. that is just from what I know don't take it for fact but I hope it gives you things to think about
Old Jan 21, 2008 | 05:19 PM
Mtman6698's Avatar
Nice ride... Identical to mine but yours looks a whole lot nicer. I'd be happy to swap notes with ya, if ya want...
Old Jan 21, 2008 | 05:57 PM
mr_diy's Avatar
thanks, I'll keep ya posted on that. I can't wait to get this thing at least looking like I want.. then on to performance
Old Jan 21, 2008 | 06:59 PM
Ru rammin 2?'s Avatar
I cut the cat conv. off of mine and my dad's and that helped the mileage and the power some. the other thing I recommend is put the bigger wheel cylinders in from napa. part# 37337 I believe. $16 and I already see the difference in mine. especially for towing. Other than that I bet you got it. That is a nice truck and I bet that if you keep it clean it should hold the value. good luck. By the way, I also recommend bhaf #2790 from napa and a pre filter from outerwears.
Old Jan 22, 2008 | 04:46 PM
mr_diy's Avatar
thanks... the wheel cylinder upgrade is a first I've heard. thanks
Old Jan 26, 2008 | 09:16 AM
mr_diy's Avatar
so what transmission do I have?
Old Jan 26, 2008 | 11:18 AM
Mtman6698's Avatar
Probably a 47RE.
Old Jan 27, 2008 | 12:57 PM
Baja's Avatar
Concerning the throttle cable, check with the dealer for recall #970 (I think). No matter, there was a recall that replaces the cable due to fraying and sticking. Free fix.
Old Jan 27, 2008 | 02:05 PM
Mtman6698's Avatar
Baja is right about the recall on the throttle cable... there was also one on the secondary hood latch (#973) and one on the vacuum check valve(#720).
FYI, dealers have the ability to produce a "Vehicle Information Plus Summary Report" that will tell you a bunch of stuff about your truck, e.g. when and where it was first sold, what recall work has been done, warranty info, dealer work done in the last couple years, and a pretty good description of the truck itself(eng, trans, paint, etc.).
~Wayne
Old Jan 27, 2008 | 08:24 PM
mr_diy's Avatar
47re.... How can I be sure. my truck doesn't have a manual with it? is it cast into the trans somewhere?
Old Jan 28, 2008 | 08:57 AM
patdaly's Avatar
96 to 2002 were all 47RE
94/95 were RH and are slightly shorter.
Old Jan 28, 2008 | 07:35 PM
mr_diy's Avatar
thanks patdaly.... I appreciate it.
Road Traveler
81
Nov 13, 2009 07:04 AM
Mark Thomas
Apr 30, 2006 08:20 AM
Intercooler
Jun 4, 2005 07:48 PM
routerguy99
17
Aug 11, 2003 12:21 PM
Nuttymopar
Apr 25, 2003 02:17 AM
