weird engine stalling
Old Aug 5, 2009 | 10:36 AM
johnt4's Avatar
Started my truck today (after making a few stops.. the engine was warmed up) and as I pushed the accelerator, it stalled.
Restarted, stalled again. 3 or 4 times, same thing. Turned off A/C then suddenly it seemed ok. A/C back on, still ok.
I mention the A/C because I recently had the evaporator replaced which involved removing the dash. Also recently replaced the fan clutch.
This is a 12 Valve '96 cummins 177K miles.
I know this is vague, but any ideas?
Thanks
Old Aug 5, 2009 | 11:44 AM
patdaly's Avatar
What is your Idle RPM with AC on, in gear?
If it isn't 750-800, you need to get it up there.
Could also be starting to plug Fuel filter/Pre-filter.
Old Aug 5, 2009 | 12:32 PM
infidel's Avatar
Turn up the idle.
Instructions> http://dodgeram.org/tech/dsl/adjustm...d_Gen-Idle.htm
Old Aug 5, 2009 | 01:29 PM
johnt4's Avatar
Idle is fine. this happens as I am actually driving, or at least getting up to speed. Thanks, again
Old Aug 12, 2009 | 01:47 PM
albacore's Avatar
Mine had an isue with dying once the engine warmed up a bit. Injector pump
needed re-timed.
Common
Apr 9, 2008 10:25 PM
matt02dodge
Dec 24, 2006 10:52 AM
n0ne
Oct 28, 2006 10:54 AM
boydwired
Sep 14, 2006 09:53 AM
JIT
Sep 8, 2006 04:13 PM
