Transfer Case Swap
Old Aug 11, 2009 | 07:25 AM
dodgeramrod's Avatar
Transfer Case Swap
The transfer case went out in my truck, but I found one close out of a 2001 cummins with the NV5600. Question is, are the transfer cases behind the NV4500 and the NV5600 interchangable? Thanks
Jim
Old Aug 11, 2009 | 07:36 AM
patdaly's Avatar
Pretty sure all the 5600's had the NV271 instead of the 241.
Some swapping around and cutting.
Old Aug 11, 2009 | 07:39 AM
He says its a 241 DLD out of an 2001 6-speed, so I don't know what the deal is.
Old Aug 11, 2009 | 01:48 PM
Tate's Avatar
The 2nd gens had 241's. I know getblown5.9 did a 271 swap into his '02 6-speed a while back. There should be posts of it on here.
Old Aug 11, 2009 | 04:52 PM
so it will swap with my 96 241 behind a nv4500? thanks
jim
Old Aug 11, 2009 | 05:05 PM
patdaly's Avatar
If that is the case, then the only holdup should be the input splines, not sure about any differences there.
Old Aug 11, 2009 | 05:11 PM
Mine are 29 spline and so is the donor. Should work, thanks guys.
Jim
Old Aug 11, 2009 | 10:55 PM
Lil Dog's Avatar
Good luck with the swap. I have had mine apart and for $150 I put in a set of bearings for a refresh. The chain and sprockets would have added about another $500, but mine were good enough. Easy to repair.
Old Aug 12, 2009 | 07:51 AM
patdaly's Avatar
Just re-read that , there is a difference between the DLD and the DHD, make sure both are DLD or DHD, then it should be a bolt in.
Some silliness with the transfer case lever mounting, but I "think" that is in the trans, not the TC.
Old Aug 12, 2009 | 02:19 PM
both are DLDs. Thanks
Jim
wyododge
Aug 18, 2011 07:48 AM
EClancy
Feb 10, 2008 09:49 AM
rhino 660
Apr 22, 2007 10:26 PM
getblown5.9
Jan 27, 2007 01:36 AM
