verify that I have a 3k GSK
Old Jul 11, 2011 | 02:40 PM
esde's Avatar
My trucks previous owner told me that the GSK was installed, but he told me some other things that have turned out to not be exactly true also. The truck revs right to 3000 rpm and not a hair above. Are those stock springs? I don't want to break out the flashlights and long magnets just to find out..
Thanks in advance, as always..
Old Jul 11, 2011 | 03:14 PM
jstone44720's Avatar
Will it pull under load to 3k, or just free rev to 3k? If it has power above 2700, then you probably have the springs in, but maybe set a little loose.
Old Jul 11, 2011 | 03:35 PM
esde's Avatar
No not under a load, it hits a hair over 2800 under load. 3000 rpm is in neutral, and it's not exactly fast to get there either. The engine has great power and torque, just no speed. While tuning my AFC, and pump timing, it sure would be nice to figure out what governor spring was in it. I'm currently running a 6 plate, boost elbow, BHAF, Goerend triple disc, and gauges. Timing is probably stock, I ordered the kit to reset timing to around 15 degrees. I have the shitty California P Pump, and am on the hunt for a used 215 pump. My goal is to tune the thing for all I can get with a stock HX35 turbo and slightly tweaked injectors.
Old Jul 11, 2011 | 03:52 PM
Lil Dog's Avatar
IMHO, not a 3K kit. With the 3K kit I can rev loaded to near 34-3500, never tried free reving it. Those numbers you describe sound stock to me.
Old Jul 11, 2011 | 05:47 PM
csa's Avatar
csa
ya thats stock...3k spring will take it past 3000 under load..
Old Jul 12, 2011 | 12:44 AM
joem's Avatar
i know my 12 valve wont rev past 2700 under load, like 3rd (automatic) pinned it wont break 2700, not sure if id want to spin a 12 valve up past 3200 much though.
Old Jul 12, 2011 | 05:00 PM
nuttynotty's Avatar
Sounds like you have 3k springs, stock you have power to 2.2k then nothing... with 3k springs you will have power up to 2.7k ~3k pending how the PO installed them. I say you have 3K springs
Old Jul 12, 2011 | 06:13 PM
gorms's Avatar
Factory settings (right from the manual) are 3000rpm high idle no load and 2700 governed under load. What you're describing sounds exactly like my truck was when stock, and I have a 98 Cali (egr) 180 hp model. I think earlier, lower HP rated pumps started running out of steam a bit earlier with less timing and fuel overall.
With 3k RPM springs it starts slowing down around 2800, will go to 3200 under load though. Now I just run the 4k springs and use my eyes and ears to keep it from blowing up.
Old Jul 13, 2011 | 01:12 PM
MikeR's Avatar
Yes it will depend on how the previous guy set them. Too loose and they won't rev high enough. Too tight and the throttle gets too touchy.
But for an automatic truck sounds kinda stock, but kind of strong if they are stock. You gotta watch the boost gauge to see what rpm the power fall-off happens at, not idle revving.
Old Jul 13, 2011 | 08:03 PM
csa's Avatar
csa
ya but he is reving it in neutral...my stock gv springs will do that but only 2600+ under full load
Old Jul 13, 2011 | 11:18 PM
joem's Avatar
just put my stock 1995 to the floor in N, 3,000 on the nose
Old Jul 14, 2011 | 01:30 AM
esde's Avatar
http://www.youtube.com/watch?v=-y44YMuFjzY
Based on this, and other searches, I'll bet the springs are stock. I will have them changed out when I do the pump timing. I "may" have a 215 pump on the line, so whatever pump gets installed will get the spring kit, and about 15 degrees.
nvr-enuf
Aug 29, 2008 07:37 AM
svanni
Mar 24, 2008 03:53 PM
BigWaylon
Apr 24, 2006 11:50 AM
pquestad
Nov 29, 2005 05:06 PM
