Valve Lash ???
Old Sep 16, 2006 | 11:57 PM
wrongway's Avatar
Valve Lash ???
I'm sure someone could tell me what the valve lash is on a 97 12 Valve. I don't think mine have ever been adjusted in 235,000 mile's. Thank's for the help. Gary
Old Sep 17, 2006 | 01:30 AM
STACKED's Avatar
.010" intake, .020" exhaust is what it calls for but you might try a little tighter on both of them i do .08" and .018".
Old Sep 17, 2006 | 06:33 PM
jimk's Avatar
valve lash
That is what I run .08 .018 good luck Jim
Old Sep 17, 2006 | 06:52 PM
infidel's Avatar
Tell us what you find.
The only time mine needed adjustment was the first time at 24k, after that they have been right on. Over 200k on both my rigs.
Old Sep 18, 2006 | 08:26 AM
rharveysr's Avatar
Why???? I set mine at 10 and 20 and it seems that I have a little valve train noise..
I just had a free Saturday when I could have run the valves again..
Rick
Old Sep 19, 2006 | 10:25 PM
74dart's Avatar
its also listed on the engine data plate on the side of the timing cover for future reference.
Old Sep 20, 2006 | 09:23 PM
jimk's Avatar
valve lash
Rick
I use to change the lash on my hot rod when I had one. You could tame it or make it pull like there was no next day. I had a 600 isky roller and it called for .030 hot on both. I have ran it at .016 and 0.18 darn it was a long time ago. You have to be carefull and many things play into that.
One of the guys that I respect that works in a Diesel shop that posts a lot on the forum told me to do that. ( .008 - .018) What you are doing make the cam a little bigger or a least a tad. Now on the hot rod when you tighten down the valve lash it would idle different and pull up to 9500 in a short order. I had the rev limet set to 7500. I remember the 427 that had aluminum heads and the lash changed a lot with heat. Or it seemed that way. That was a long time ago. I still would like to build one more some day. This time I will take rod ratio into account. I like to use the longest rod that is possible. Jim
Old Sep 20, 2006 | 10:31 PM
fschiola's Avatar
Check out this thread for some info.
https://www.dieseltruckresource.com/...lve+adjustment
REDNECK-WELDING
Apr 4, 2008 06:06 PM
AKDSLDOG
Jun 2, 2005 09:49 PM
Sgregory
Mar 5, 2005 07:21 AM
ARAcummins
Dec 6, 2004 09:38 AM
linetrash75
Jan 3, 2004 07:06 PM
