Vacuum sensor ????
Old Aug 29, 2006 | 07:01 PM
dslpower's Avatar
Vacuum sensor ????
What does this thing actually do?? I'm fairly sure it tells the PCM theres vacuum But how to test it? It does'nt tell anything about it in the books. Anyone know how to check it?? Thanks.
Old Aug 29, 2006 | 07:05 PM
infidel's Avatar
It's just a simple switch. If it doesn't work or you really do lose vacuum the dash brake light warning comes on.
Old Aug 29, 2006 | 08:20 PM
DuallyMan's Avatar
Are you talking about the red brake light, on the dash. I have the same problem. I just replaced my vacum lines that controlled the Cruise control and the AC controls. My brake light has been on for as long as I know. Do you think if I replaced my vacum sensor then my brake light would go off.
Old Aug 29, 2006 | 08:43 PM
dslpower's Avatar
Thanks for the info infidel.
I have been trying to figure out why I dont have TC lock-up (at all) and why the cruise doesnt work. Checked/cleaned everything else. Going to put a switch on it tomorrow and see if it will lock manually.
Old Aug 30, 2006 | 10:33 AM
infidel's Avatar
It could. The problem might also be your parking brake switch. The PB switch is so cheap it's totally amazing it works at all.
Old Aug 30, 2006 | 07:25 PM
DuallyMan's Avatar
Thanks for the help Infidel. I'll try and get one this week, and see if it works. Do you have a part # for it.
Old Aug 31, 2006 | 10:49 AM
infidel's Avatar
Sorry, no
Old Aug 31, 2006 | 05:59 PM
gmctd's Avatar
The emer brake switch can be easily repaired - take a look and see if it is bent.
The vacuum switch can be tested with a hand vacuum pump - pump it down and the lite should go off - no use pulling the connector, 'cause the lite will just stay on
jimbo486
May 8, 2016 06:07 PM
soggy
Feb 24, 2011 05:01 PM
TJE
Oct 10, 2007 04:49 PM
wannadiesel
Oct 14, 2005 06:15 PM
