Vacuum Pumps
Old Oct 5, 2010 | 08:03 AM
Greguw's Avatar
Vacuum Pumps
Does anyone know if a 24 valve vacuum pump will work on a 12 valve . I have one off a 1999 with the pump thats connected ... I need the Hydro return port for my truck .
I have both versions but have not pull anything apart yet ...
The 24 pump looks to have a longer front shaft and may come close to the timing cover .
I guess I will answer my own question ... I pulled off the original 1996 one , the newer 24 valve fits great , good gear mesh . Had to remove the return throttle spring bracket and required a little trimming due to the larger steering pump ... little knotch and it was fine .
Also have to extend the oil feed line .
I did not have to change the power steering feed line ... This 12 valve is going in a cheby ... Had the power steer line and it was the same .
pokeypennell
Jun 26, 2007 07:02 AM
mattme
Jan 31, 2007 06:26 AM
Ilikebikes
Dec 11, 2006 10:13 PM
Contractor
Jan 18, 2005 08:13 PM
Ggg
Dec 13, 2004 08:07 PM
