Vacuum Hose at the Vacuum pump
Old May 29, 2022 | 09:54 PM
John 313's Avatar
All of my vac. line is gone along with the connectors on my 97 Dodge 2500 12v 2wd 5 speed (Fire). My question is: What size is the adaptor that connects the 1/8 in Vac line to the Vac. Pump. It's Memorial Day Weekend and I have had no luck with any of the auto parts stores. As an aside If I knew the size of the fitting on the pump I could just run that size hose to the brake booster and then branch off from there. What do you think? I'm not the brightest bulb in the lamp and I value your opinions and advice. Semper Fi, well done to all of our fallen Vets and their families..
AIN'T GOTTA BE EASY, JUST GOTTA BE DONE
Old May 31, 2022 | 10:05 AM
texasprd's Avatar
Originally Posted by John 313
If I knew the size of the fitting on the pump...
Do you have a tape-measure?
Sorry to hear about the fire - that's a scary scenario. I hope it didn't do a lot of damage to wiring, suspension, brake system, etc.
Old May 31, 2022 | 11:19 AM
John 313's Avatar
Thanks for the reply. The parts guy at NAPA found me one. Thanks anyway.
Old May 31, 2022 | 02:38 PM
texasprd's Avatar
Glad you found what you needed.
For measuring things like you needed, I have a steel version of this pocket caliper - it's been most handy over the years.
Old May 31, 2022 | 05:30 PM
John 313's Avatar
Thanks, just picked one up at Harbor Freight, the parts guy made the same suggestion.
Hdog
Feb 25, 2013 01:33 PM
Fallfork
Apr 7, 2008 12:10 PM
pokeypennell
Jun 26, 2007 07:02 AM
