Unusual Surging Problem
Old Apr 17, 2011 | 03:02 PM
diesel96's Avatar
My gas pedal is very sensitive. Whenever I go over rough ground, especially washboard, the slight movement in my foot causes quick acceleration and deceleration. This results in a violent jerking motion. The pedal seems to be firm with the motor turned off, then very light with the motor running. I have to rectify this before I damage the powertrain. There is no problem with the cruise control activated. Has anyone had a similar problem??
Old Apr 17, 2011 | 04:18 PM
RichN's Avatar
Can't help you, but I have the same problem. Mine does it with light throttle in second or third gear. My transfer case mount is new, haven't checked the motor mounts though.
Old Apr 17, 2011 | 07:07 PM
Tate's Avatar
Get some more return springs on your throttle linkage. Or get more control in the muscles in your foot. I've had the same issues with 5k gov springs and big injectors, but you're a ways off that. My dad had issues with that in my daily driver, but I can drive it smoothly. I pulled a couple of the return springs off my throttle linkage because I like the light pedal.
Old Apr 18, 2011 | 09:39 AM
diesel96's Avatar
This problem only showed up recently. There is only 1 spring in the throttle linkage that I can see. Could I have lost or broken a spring? Is there more than one?
Old Apr 18, 2011 | 09:57 AM
infidel's Avatar
There's supposed to be two springs.
On some years they are side by side, on others one inside the other.
Very common for one or both to break or fall off causing a sensitive pedal.
New springs are $9 each from the dealer or much cheaper and easier from the the auto parts or hardware store for a generic spring.
Old Apr 18, 2011 | 10:34 AM
diesel96's Avatar
THANKYOU.....Infidel, I may try elastic bands so I can get the tension I want before I get a spring. Thanks to everyone for their imput.
p0wd3rp1l0t
Apr 1, 2012 02:34 PM
ado2b1
Dec 5, 2008 06:25 PM
blacklab467
19
Jul 26, 2008 12:56 PM
addecus
14
Jul 10, 2005 11:40 PM
DPG
Mar 27, 2003 08:30 PM
