Was under the truck today and noticed a purple tag...
Old Mar 11, 2011 | 08:39 PM
Saileron's Avatar
Question Was under the truck today and noticed a purple tag...
on the new transmission (10k miles on it) fill plug - it says:
Refill with
46375779
I assume this is the dealer part number for Syntorque gear oil (I hope). Can anyone verify this!
Old Mar 11, 2011 | 09:57 PM
cj360trider's Avatar
give your dealer a quick call and see if its a good PN for them and what it is....
Old Mar 14, 2011 | 10:48 AM
Saileron's Avatar
Checked with the dealer this morning and sure enough - that's the new Dodge part number for the Syntorque gear oil.
Old Mar 14, 2011 | 11:20 AM
Lil Dog's Avatar
Good to know. For future oil changes..Thanks
Old Mar 15, 2011 | 09:57 AM
infidel's Avatar
By far the best price on Syntorq, $52 for 5 quarts.
It's the real stuff.
You have to call http://www.blumenthalautomatics.com/index.htm
Old Mar 15, 2011 | 11:17 AM
12ValverDave's Avatar
You running 5 qts in yours? My FSM says 4 qts and if I fill using the the fill plug it only holds four.
Old Mar 15, 2011 | 02:19 PM
lgp9999's Avatar
You're right, 12Valver, but most of the NV4500 experts recommend to dump an extra quart in through the shifter. The reason is is because the input shaft bearing is located higher than the fill plug, so an extra quart will help keep that lubed.
Old Mar 15, 2011 | 03:14 PM
Andy505's Avatar
Mine has had 5-6 quarts of liquid gold in it since I had her rebuilt about a year ago.
Old Mar 15, 2011 | 06:39 PM
will it quiet it down any?
Old Mar 16, 2011 | 01:16 AM
lgp9999's Avatar
Amsoil took away the noise mine used to make.
Old Mar 16, 2011 | 10:28 AM
infidel's Avatar
I don't believe in more is better.
The engineers that designed the NV know exactly how much fluid is optimum for their trannys or they would have put the fill plug higher.
I've been running 4 quarts for over 200k trouble free miles towing 26k lbs everyday for six months out of the year.
If more is really better it's taking it's sweet time to show up.
renotype
Aug 12, 2008 10:28 PM
Roperteacher
Jul 15, 2007 07:11 PM
nfsommer
Nov 21, 2006 09:34 AM
dieselnewbie
Mar 28, 2006 09:45 PM
steelydan
Oct 25, 2004 10:06 PM
