Truck will not start HELP!!
Old Jul 23, 2010 | 01:49 PM
bimmerboy86's Avatar
So i got home from work turned off the truck. went out the next morning to go to work and it started, ran for about 20 seconds then started stumbling like it was running out of fuel. messed with it for about 10 min then had to get to work. i thought maybe i missed calculated and it was out of fuel. well i changed the fuel filter and no change. added 5 gal of fuel, no change. i am getting fuel to the ip by manually priming lp. no fuel out of the delivery valves. were do i go next? any help would be greatly appreciated. thanks
Old Jul 23, 2010 | 02:16 PM
rattlerbob5.9's Avatar
Check at the fuel shut off solenoid to see if it is pulling all the way up when cranking and then staying up in the run position.
Blue wire from the battery feeds to it and can get corroded also contacts on the relay located by the cowl can go bad. It is rare but the fuel pump solenoid can go bad also check to see if it moves freely and not hung up with dirt or rust due to a torn boot.
Old Jul 23, 2010 | 04:27 PM
i forgot to mention i wired it up. thanks for the reply.
Mods please delete thread. problem solved. Thanks
Old Jul 23, 2010 | 04:51 PM
Please let us know what you found wrong so that everyone else here can learn from it.
We normally don't delete threads and if we did so very few lessons would be available here for people to gain knowledge from.
Old Jul 24, 2010 | 09:23 AM
blackimpala's Avatar
I agree
Yes you should post what you found. People are quick to ask for help, but some aren't as quick to offer help.
Floyd
Old Jul 24, 2010 | 06:32 PM
ended up being the overflow valve.
Old Jul 24, 2010 | 09:39 PM
Thanks for the answer.
Did it not act up or run weird at all prior to this ? Such as low power or smoke ?
Old Jul 25, 2010 | 07:16 PM
well its a stock auto, so compared to my lightly bombed 5 spd i used to have it always felt a little low on power haha.
FirstGen1991
Dec 22, 2012 04:24 PM
TNDODGE
Sep 13, 2012 01:38 PM
loosendend
Sep 4, 2006 12:01 PM
loosendend
Aug 20, 2006 09:27 AM
whiteknight
Sep 23, 2003 11:59 AM
